Home > Maintenance & Modifications > For those who aren’t married.
Bluest
If you are single, or otherwise of independent financial means, begin drooling now. British made too
 2007 110 TDCi Station Wagon XS
Post #924871 7th Oct 2021 4:36pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I guess it maybe cheeper to get married Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #924874 7th Oct 2021 4:55pm
Dinnu
By the hub bolt pattern, looks like it is made for a Series, not a Defender axle. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #924875 7th Oct 2021 5:01pm
Bluest
That could be true, they do a lot of other series stuff. 2007 110 TDCi Station Wagon XS
Post #924876 7th Oct 2021 5:18pm
Co1
It can’t be THAT expensive!! Rolling with laughter
Post #924878 7th Oct 2021 5:28pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
If you think getting married is expensive, wait until you get divorced. Rolling with laughter
Post #924879 7th Oct 2021 5:42pm
Co1
Rolling with laughter Rolling with laughter Rolling with laughter
Post #924885 7th Oct 2021 6:17pm
Race.it
Yep divorce costs more than the marriage. You loose things you never knew you owned. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #924894 7th Oct 2021 7:31pm
Looks like the Tibus unit that G wagens can have.
Post #924899 7th Oct 2021 7:42pm
Hufflepuff
Ooooh its a Portal axle? I thought it was a tool for manufacturing a steel rim, right now I understand why you guys are saying its not going to be cheap.
Their Defendery bits on on:
https://www.designdevelopmenteng.co.uk/sho...c115811253
'Reassuringly expensive' but not outragous? 2005 Td5 90 XS
1989 V8 110 CSW
Post #924913 7th Oct 2021 8:38pm
Curious about these ~ anyone any experience?
Snap Fit Security Bonnet Bush
Post #924955 8th Oct 2021 8:25am
I've got a set to fit but not had chance yet. Darren
Post #924978 8th Oct 2021 10:29am
From what I have seen of their engineering, the stuff from these guys is pretty good. I have one of their modified Disco2 ACE valve blocks to fit on my Disco (not fitted yet) and the workmanship is excellent. I am also lead to understand (by them) that they did much of the engineering behind the LOF one-piece adaptor shaft as well.
If they are now making bolt-on portal kits it is a very interesting development, but don't expect them to be remotely cheap either in price or quality.
The general problem with bolt-on portals is that the axle isn't really strong enough for the portals. Tibus has done quite a lot of work to overcome this and it will be interesting to see how D&D address the problem.
Post #924983 8th Oct 2021 11:24am
Devon-Rover
I have their disc brake conversion brackets on the series and the quality of the machining work is very very nice.
Bryan is a great chap to deal with too, their customer service I can't fault. Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #925013 8th Oct 2021 4:37pm
