Home > My Defender > Puma to LT1/8L90 Restomod
Page 21 of 41 <123 ... 202122 ... 394041>
Procta
mrfirepro wrote:
Finally started looking like a vehicle again, got the bulkhead in and the new mounts welded in.
One of my mistakes when fitting the trial (bare) bulkhead was not allowing the blower box, it does fit with the 90mm engine move but by luck not judgement.
Looking back at this it is looking like the 60mm move would be the optimum, this will only be known for sure if there is 30mm in the front to spare, will be interesting to see how this pans out.
Some photos as normal
workshop is it's usual tidy self... Laughing
What a build!!! last time i saw this thread, you had just got it! Engine conversions really do take some time. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #918814 26th Aug 2021 5:06pm
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Got the new fuel lines in
And new rear brake lines
Going to need the seat box soon, had to install two new end panels due to corrosion, base has had it's first coat of EM121, seam sealer everywhere, then top coat then second coat of 121. (really can't believe there was almost no seam sealer Rolling Eyes Rolling Eyes Rolling Eyes ) hopefully now it will float if needed Rolling with laughter
My next move is to get this thing running to check the fuel system before installing the tub
Post #919377 31st Aug 2021 6:11pm
Co1
First run video is mandatory!!
Install looks very tidy indeed. Nice work.
Post #919394 31st Aug 2021 7:17pm
JOW240725
Shocked Cool Bow down Thumbs Up James
Instagram @suffolk_rovers
Post #919462 1st Sep 2021 5:49am
mrfirepro
Seat box and windscreen surround is now together and back from the Bodyshop
Both rotten ends have been replaced, the YRM parts were easy and a great fit
Old/New
The underside has had it's first two coats of EM121 which will be followed by two coats of Lizardskin sound deadening and two coats of ceramic insulation, will do the same to the underside of the tub whilst I'm at it.
I don’t plan on 100% dynamat inside the seatbox as I did for the bulkhead but will probably just do the sides and bottom.
I'm using an electronic handbrake so have made a cover plate for the holes
The plate is bonded in, but I forgot to remove the bolts before painting so just deciding if I should remove them or leave them in place....Dooohh
I've also cracked the sump installing the catch can return to the sump.
The upside of this is that now I'll have a properly welded solution as I may as well get the adapter permanently welded in when the sump is fixed.
The manifolds are already ceramic coated but in my quest to control heat I plan to double wrap with Titanium exhaust wrap.
Post #921663 15th Sep 2021 8:53pm
Linds Hanson
Great work
Post #921723 16th Sep 2021 2:39pm
mrfirepro
The sump has been welded with a new an-8 adapter for the oil return between the catch can and sump.
Recieved the new system ECU from Futuranet this week. this will replace the LR ECU and interface with the GM system controllers. Futuranet have also interfaced a TMPS system onto the LR system which hopefully (still work in progress) will display on a new display in the middle of the cluster.
Here it is in it's final position with the FPR & Oil catch Can
With the help of Martin (futuranet) we have decided to ditch the use of the OE connector for the fuel pump due to the current rating and opt for a connector more suited to the 11ish amps of the fuel pump.
Post #924272 3rd Oct 2021 6:20pm
Black Puma
United Kingdom 2011 Defender 90 Puma 2.4 SW Sumatra Black
Excellent job as usual. Always a pleasure to drop in on this thread.
From memory, I maybe wrong, you mentioned 2 years for the project. 11 months or so into the build. Appears you are making solid progress at this point.
Thumbs Up
Post #924299 4th Oct 2021 2:05am
mrfirepro
Been a little slow the last few weeks..
Tidied up the loom to the rear and added in extra wires for the fuel pump
Now all installed and the fuel system is working at 75psi without any leaks, must have been my lucky day Laughing
Next step is to get the rear tub and seat box installed but first some lizardskin as I finally got my order from Buzzweld after some considerable time despite saying it was in stock Evil or Very Mad
Started with the seat box which had already been coated with EM121
prep
first coat when wet
Finished item with sound deadening coating finished, just ceramic insulation to go
Started the Dynamat inside as well, as the results with the Lizardskin were OK but nothing like Dynamat.
And finally got around to finishing the diff lock linkages.
Post #926908 23rd Oct 2021 10:40pm
Pickles
Brilliant work.
Pickles.
Post #926912 24th Oct 2021 5:14am
Co1
Bow down
Post #926919 24th Oct 2021 7:20am
mcma1
Excellent stuff Paul. By far the best conversion I have seen. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #926939 24th Oct 2021 11:31am
mrfirepro
Been a bit slow had to finish another project for the classic car show at the NEC, but there has been a little bit of progress....
Im now starting to think about the exhaust and getting the body and seatbox installed to release the electronics.
I've got the complete fuel system up and running, pressure tested and set up
Finished off the mods to the hi/Lo linkage and fitted the cowel
Treated the underside of the seat box with two coats of Lizard skin sound deadening and two coats of ceramic insulation.
And completed the internal sound deadening
I've isolated everything using expoxy however I'm still using some rubber gaskets
Modified some standard LR power steering hoses to fit...
started fitting up some of the stainless parts so I don't lose them
Prepping the dash for switch panel and double din, prior to trimming in leather
Not very impressed with the Defender Upgrades switch panel, the fit is not great, perhaps if anyone knows of a better quality panel let me know.
I've ordered new wings so starting to fit up the old wings to make sure everything fits and I can start to get my head around the design of the cooling and cold air intake
I appreciate all of the feedback and positive comments and very much welcome any suggestions.
I'm just about to order everything I need internally and externally from Croytec and I'm still looking for someone to do the leather trim for me.
Post #933034 9th Dec 2021 11:05pm
Procta
have you done a 1st start? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #933038 10th Dec 2021 5:38am
JOW240725
Great update thank you! Starting to take shape now Thumbs Up
For leatherwork have a look at https://www.marshlandupholstery.com/ they do some pretty impressive work. They did the interior for Giles English (Bremont Watches) Lightweight recently 'restored' by Hayward Revive. Looks amazing. James
Post #933042 10th Dec 2021 6:16am
