Home > 130 > Smyles_ Cummins 130 Build Thread
Page 7 of 10 <12345678910>
L110CDL
Yep very nice Cool 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #915843 6th Aug 2021 7:54pm
Smyles_
Denmark
Co1 wrote:
Nice. I know it’s as long as a piece of string, but any idea how long you’ll have to wait until you get it back on the road?
Well unfortunately one of the mechanics is self-iso currently so that doesn't help things but looking at mid/late Sept now which is fine by me Smile
JOW240725 wrote:
That looks lovely! Thumbs Up
I assume the blacking is just for visual looks more than protection of the galv? Out of interest do they use a cavity wax internally? Or is this more likely to do damage trapping moisture inside?
I honestly can't remember what exactly was applied, I'm totally useless I know. I just left it up to the experts at the blasters/galvanisers to decide, but I'll find out for you this week. Pretty sure it was not dipped but that doesn't answer much Snigger
L110CDL wrote:
Yep very nice Cool
Thanks Clayton!! Very Happy
Pics as promised, albeit rather late cause of work...
Small amount of pitting on the rear crossmember and what you can see on the outer face of the outriggers, other than that the rest is just dust from transit.
Also, please excuse the state of their floor - they're rather embarrassed by it, they think it makes them look like a sloppy outfit which they couldn't be further from - it's getting repainted soon! Laughing Stuart
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #916135 8th Aug 2021 8:14pm
Dinnu
Best finish on a galvanized chassis that I have ever seen.
So if I may ask, what type of galvanizing have been applied? My rough guess is that it is not hot dipped, but perhaps zinc metallizing? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #916148 9th Aug 2021 5:37am
JOW240725
It looks an incrediable finish when you look at the before and after! Wow! Thumbs Up
I keep finding myself looking at 130's, so want one! James
Instagram @suffolk_rovers
Post #916199 9th Aug 2021 1:03pm
Smyles_
Denmark
Join us James! Stuart
Instagram
Post #916201 9th Aug 2021 1:09pm
Smyles_
Denmark
So I have had several deliveries this week...
Been thinking plenty about engine monitoring and how the Cummins being entirely devoid of electronics will require mechanical gauges or electronic sending units.
So the fist few gauges that I've purchased for now (holy Censored they are expensive) are from Smiths Classic Magnolia line.
(Turbo boost pressure - yes I know, it's a diesel and it wont make -ve pressure, it's from a classic mini)
(Oil Pressure and Water Temperature)
The boost pressure gauge (no longer manufactured Sad ) is a stepper motor and will require an electrical boost pressure sender (this one w/ 1/4" male NPT) and will sit in a Raptor Engineering Puma Dash Pod along with 3 other 52 mm dia. gauges from Smiths (thinking fuel, volts, and ammeter, all magnolia also).
I suspect I will eventually, once financially recovered, retrim this excluding the brushed face, in a Harris tweed previously shown.
The temp/pressure gauge is a big boy and I have a problem. It wont bloody well fit in the raptor dash...
(the bend protected pipe is the limiting factor not the black pressure pipe)
I suspect I will either have to mount this where the Puma's temp/fuel gauge usually resides:
Oorrrrr... well I don't know to be honest... an angled spacer or locate it near the knee like those switch panels?
I don't know, thoughts would be appreciated! Anyone know how much room there is behind the stock fuel/temp gauge?
Anyway, the rest of this post you can all ignore as it for my sanity only given the amount of metric, imperial, and converting connectors that arrived today from RS Components for the pneumatic element of the build...
(10 mm to 6 mm push connector)
(3/8" to 3/8" 90 - RS components said it was 3/8" to 10 mm Evil or Very Mad )
(NPT female 1/4" to NPT male 1/8" - inlet manifold boost pressure Question can't remember...)
(10 mm to 1/4" NPT - air res to manifold)
(G1/2" to 10 mm push - manifold inlets)
(Female R1/4" to 6 mm push - pressure gauge)
(10 mm push plugs)
(6x 10 mm push manifold with 2x G1/2" inlets)
(10 mm or 3/8" hose clamps)
(Stainless steel worm drive hose clips 11 - 16 mm)
(3/8" PCL fittings for air tools - female mounted to F/R bumpers)
(10 Bar 50 mm gauge w/ R1/4" male thread - air tank pressure)
And I have even more arriving soon with about 100 m of air lines in varying ODs... don't mix imperial with metric kids Big Cry
Next on the to-buy list is the hi lo diff lock pneumatic actuators, air tank, and maybe (definitely) air horns Razz Stuart
Instagram
Post #916828 13th Aug 2021 9:10pm
Co1
This thing is going to be a beast! Keep the updates coming.
Post #916860 14th Aug 2021 7:08am
Smyles_
Denmark
So for those that were wondering about the finish:
Work was undertaken by AMD Specialist Coatings Stuart
Instagram
Post #917981 20th Aug 2021 1:05pm
Smyles_
Denmark
Rub-A-Dub-Dub, 130 Inch Tub
On Thursday we had the 130's new tub picked up locally from a lovely forum member!
Fair to say I'm one happy boy yet again - this tub is beautifully straight and practically dent-free Mr. Green
(these hinges will need a lot of lubrication to get moving again)
It's off a late model TD5 from what I've been told. And I have hood and sticks to boot! Cool
There are also some very beefy HD axles that were delivered on Friday to house the Winchester diffs that have been sitting wrapped on a pallet for a few weeks now in the garage. I'll grab some pics of them sometime next week for you all Thumbs Up
And to top it all off, this happened on Friday
If you know, you know Bow down Rolling with laughter Stuart
Instagram
Post #919017 28th Aug 2021 4:47pm
JOW240725
The envy increases! But at least I also have Lord Trousers as a follower, great account. James
Post #919035 28th Aug 2021 8:05pm
gcc130
Wow, even the tailgate is dent free Smile
Post #919037 28th Aug 2021 8:27pm
I remember having a hicap tub that had 5 hinges on it (factory fitted)....
shows the cutbacks with just 2!
Post #919047 29th Aug 2021 1:26am
L110CDL
Nice tub you have got there Thumbs Up
It's a bit harder to find a tub for the back of mine at the moment and with the knowledge of knowing where it came from Rolling Eyes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #919411 31st Aug 2021 7:50pm
Smyles_
Denmark
It's not even been built yet James - at this rate you'll probably have caved by the time I get it finished! If not I'll be sending you 130's listed for sale Thumbs Up Just commit already! Laughing
Probably my favourite purchase to date just because of this!
I was unaware of this. I'll be honest though, I don't need a 130 for hard work - in fact I cant think of a rational reason as to why I even need a Defender at all!
What's up with the current one? I always liked the look of an honest working defender Smile Stuart
Instagram
Post #920441 7th Sep 2021 6:46pm
JOW240725
Anyone wanna swap a 110 TDi for a 130 TD5 Whistle
Don't tell Seriesonenut!! Embarassed James
Post #920454 7th Sep 2021 7:24pm
