Home > Maintenance & Modifications > Difflock drain plug
Page 5 of 5 <12345
HardCharger
The sump plugs for the 2.4 Puma and the 2.2 Puma are the same size, right?
Post #918853 27th Aug 2021 7:07am
HardCharger
So it appears that M14 x 1.5 is what is needed. BUT! From this thread, the plug is available in T10, T11.5, and in the car of the Stahlbus Oil Drain Valve, 12 mm. Does the T(whatever) matter or they will all work regardless?
The Femco Drain Valve is brass(?). While Stahlbus is steel. Will the valve material have any effects down the line when installed in the sump?
Thanks.
Post #919292 31st Aug 2021 8:16am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Femco do two types that will fit a 2.4 Puma -
Standard LB 6090020086 M14X1,5-T12 (I have this and it fits fine)
and small. Not sure on the specifications for the small but part numbers are:
DP1039 M14x1.5 Small Series
DP1019D 90 degree Small series hose, 250mm
Post #919785 3rd Sep 2021 12:24pm
Bluest
What length drain hose is best for Puma when draining the oil on normal ramps? 2007 110 TDCi Station Wagon XS
Post #920081 5th Sep 2021 10:47am
kmac
I have a 25cm one and it is fine. Mind you I don't use ramps, just change the oil and filter with the car on the wheels
Post #920142 5th Sep 2021 8:51pm
Bluest
Got mine delivered today, very quick service, price was £52, but realised I should have asked for 90deg drain hose as they’ve sent a straight one. Going to see if I can exchange it. 2007 110 TDCi Station Wagon XS
Post #920326 7th Sep 2021 8:24am
hank
I did an oil change over the Christmas break so fitted my Femco drain plug...
I torqued it up as per the instructions but made the fatal mistake of thinking "that doesn't seem tight enough to seal the copper washer, I'll just give it one more nip"
Instantly it felt as though the threads had stripped. They hadn't, it was the body of the drain plug shearing off the threaded section.
Moral of the story, do not tighten beyond the torque setting Embarassed > 110 XS Double Cab
Post #938626 21st Jan 2022 9:01am
geobloke
Yup, been there done that, flippin' irritating. Superb drain plugs a great modification but so fragile. Confess I have gone back to a standard plug.
Post #938639 21st Jan 2022 10:26am
hank
Me too. When I saw the 'meat' that had sheared between the plug body and the threaded section I didn't think it looked as though it would take much to shear through fatigue. Showed around 0.2mm thick on the vernier callipers. Will fish it out of the bin and take a photo > 110 XS Double Cab
Post #938646 21st Jan 2022 10:54am
landy andy
I’m surprised by this. I’ve fitted at least four of these on various vehicles and haven’t had this problem. Maybe things have changed with the quality
Post #938649 21st Jan 2022 10:59am
Avelingporter
Same here. Femco plug sheared and have gone back to standard.
Post #938653 21st Jan 2022 11:25am
geobloke
You might be right about the quality of materials because the one I had fitted to my 200tdi was indestructible. It even got hit by a branch whilst green lining and survived to live another day. The one fitted to Miffy sheared when screwing on the drain pipe. Heat fatigued perhaps...?!
Post #938655 21st Jan 2022 11:29am
hank
Feels like a design error to me rather than material. The quick release body looks to be a standard design, possibly supplied with a blank end for a thread to be machined on to suit the vehicle application.
The threaded portion is too long/too close to the body leaving insufficient material between the two parts > 110 XS Double Cab
Post #938658 21st Jan 2022 11:46am
Page 5 of 5 <12345
