Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
It is pleasing and reassuring to see that the updates do work and fix faults and problems. My car is driving better since the latest update the throttle response is better. There is the argument that none of these problems should of been there to start with but at least SOTA is working and resolving albeit at a frustratingly slow pace if you look back at when I first reported the faults to JLR.
12th Jun 2021 12:48pm |
Yes just tried both 4x4i screens the pivi screen doesn’t mirror the driver display when rear differential is locking the pivi screen show’s unlocked. I can live with that atm and have faith it will get sorted through a later software update. |
14th Jun 2021 6:35pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3406 |
I don’t know if it will make a difference but there is a setting “mirror drivers display” 24MY 90 D250 HSE, Tasman Blue
14th Jun 2021 7:06pm |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
Where is that? Not seen that
Thanks |
14th Jun 2021 7:25pm |
It’s in SETTINGS - APPS - NAVIGATION - DRIVER DISPLAY
I think it’s just for navigation. My Pivi screen and drivers display both show the same info regarding the diff but there is a delay on the drivers display, it’s a second or two behind the pivi screen. 24MY 90 D250 HSE, Tasman Blue |
15th Jun 2021 10:48am |
Yes - that is Nav Only...
THANKS |
15th Jun 2021 2:13pm |
OK - so a third software OTA update in the last month - and this latest update has fixed the sync and display issues with the Diff's between the tile / dash / main screen. this one has an 'a' at the end.
It is surprising how often the rear / centre diff locks or partially locks - basically any modest acceleration sees at least a partial lock of one or both diffs and hard acceleration sees both partial / fully locked on a dry road. one down - just the ECO missing centre display issue left as far as I can tell. Then the new rattle that sounds like its coming from the screen vibrating at the top - which is probably the A pillars - despite the pillars being the newer style - (as far as I can tell) L8B2-025A53BD8PAB loose cover and l8B2-03179-AD fixed part. |
25th Jul 2021 12:29am |
5 months in and it’s showing it’s first warning.
Click image to enlarge Switched it off and back on again and so far hasn’t reappeared. Will book it in next month. 24MY 90 D250 HSE, Tasman Blue |
10th Aug 2021 2:27pm |
jmac Member Since: 04 Feb 2021 Location: Scotland Posts: 14 |
I had this come up on Saturday when on the LR Experience trek day at Dunkeld.
The instructors there weren’t concerned about it and see it on their vehicles. Apparently it is normally caused by overheating and will resolve itself pretty quickly. Now I’m not sure what the lower radiator on the 6 cylinder engines is for (bottom right when looking face on) but mine was filled with crap after wading in the pond at Dunkeld. I wonder if it somehow contributes to cooling of the diff? |
10th Aug 2021 2:38pm |
When it appeared on mine it was whenever I drove over multiple pot holes or a rough surface. Dealership did a software update to fix and it’s never been back since.
17th Aug 2021 7:22pm |
So far it’s not reappeared on mine. 24MY 90 D250 HSE, Tasman Blue
17th Aug 2021 7:31pm |
They are probably not concerned because they don't own the vehicles, the vehicles are under warranty and they are swapped out regularly. Then ask yourself why are the clutch packs overheating and medium/long term what's that doing to the components and ultimately your pocket if you pay the bills? |
18th Aug 2021 6:28am |
I think it’s software rather than overheating, I hadn’t driven mine any distance or off road for it to overheat. A quick switch off/on cured it so far. 24MY 90 D250 HSE, Tasman Blue
18th Aug 2021 11:00am |
There may well be more than one failure path and both are correct, just under different circumstances.
18th Aug 2021 11:57am |
