Home > Puma (Tdci) > Can heavy rain or car wash splash wet the air filter?
Page 2 of 2 <12
jonchongg
Singapore 2016 Defender 110 Puma 2.2 HT Montalcino Red
Julie wrote:
Exactly the same configuration and no problems. Heavy rain while overtaking lorries.
The car is LHD i.e. the RAI on the right hand side is really nearby the lorries while overtaking.
But you shouldn't blow any water inside the RAI while washing it. That's for sure.
Good to hear that. But I'm a little loss because i've never had this until this recent heavy rain.
Here's what it did:
Post #915720 6th Aug 2021 2:30am
jonchongg
It is a standard airbox and i didn't seal up any of the 'drainage' if that's what you're asking.
Here's what it did.
Post #915721 6th Aug 2021 2:32am
Dinnu
I have the RAI, with forward facing intake on my tdci, and I have been in some very heavy rain, and 'deep water' where the tyres create a huge splash forward, that end up on the windscreen (yes, with a few scary seconds were you cannot see anything).. and never had this problem.
Is that the genuine air filter? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #915724 6th Aug 2021 5:33am
bear100
the genuine filters ave a sponge top layer on them? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #915727 6th Aug 2021 6:05am
Dinnu
Yes, it is more like a mesh than a sponge, like a wooly layer, about 1cm thick, and then the paper element.
When installed, the wooly layer is on the underside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #915732 6th Aug 2021 7:27am
Bluest
Here's what it did:
Looking at the pipe from the the Airbox to the turbo it looks like your engine ingested quite a lot of filter material. 2007 110 TDCi Station Wagon XS
Post #915736 6th Aug 2021 7:38am
jonchongg
Apparently, that was pretty much it and didn't damage the MAF sensor. Cleaned it up and changed a new filter and it was running again. There were bits that blocked the MAF sensor which sent the car into limp mode (which i think was a good thing).
Post #915752 6th Aug 2021 9:12am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
It's a Moist Air Filter sensor then Laughing
Post #915822 6th Aug 2021 6:04pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Mine did exactly the same, sucked paper from the filter into the turbo inlet and jammed it up!
It was like someone had thrown a rock through wet paper. Big hole through the filter.
Thankfully the garage cleared it out with no long term damage, but was a close call! Had even ordered a replacement turbo.
Post #915906 7th Aug 2021 12:25pm
Page 2 of 2 <12
