![]() | Home > Puma (Tdci) > Can heavy rain or car wash splash wet the air filter? |
jonchongg Member Since: 02 Aug 2021 Location: Central Posts: 9 ![]() ![]() ![]() |
It is a standard airbox and i didn't seal up any of the 'drainage' if that's what you're asking.
Here's what it did. ![]() Click image to enlarge |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
I have the RAI, with forward facing intake on my tdci, and I have been in some very heavy rain, and 'deep water' where the tyres create a huge splash forward, that end up on the windscreen (yes, with a few scary seconds were you cannot see anything).. and never had this problem.
Is that the genuine air filter? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1986 ![]() ![]() ![]() |
the genuine filters ave a sponge top layer on them? 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Yes, it is more like a mesh than a sponge, like a wooly layer, about 1cm thick, and then the paper element.
When installed, the wooly layer is on the underside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4262 ![]() ![]() ![]() |
Looking at the pipe from the the Airbox to the turbo it looks like your engine ingested quite a lot of filter material. 2007 110 TDCi Station Wagon XS |
Apparently, that was pretty much it and didn't damage the MAF sensor. Cleaned it up and changed a new filter and it was running again. There were bits that blocked the MAF sensor which sent the car into limp mode (which i think was a good thing).
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
It's a Moist Air Filter sensor then ![]() |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Mine did exactly the same, sucked paper from the filter into the turbo inlet and jammed it up!
It was like someone had thrown a rock through wet paper. Big hole through the filter. ![]() Click image to enlarge Thankfully the garage cleared it out with no long term damage, but was a close call! Had even ordered a replacement turbo. |
