Home > General & Technical (L663) > CB Radio Aerial Mount
Page 1 of 3 123>
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I will be installing a CB radio in the car (when it arrives) does anybody who's coming from a D4 know whether one of Uncle Ray's aerial mounts would fit the roof rails on the New Defender? Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #915629 5th Aug 2021 2:14pm
WizzardPrang
The roof rail channel is pretty wide. I've yet to find anyone who has mounted a CB antenna on it. I've been chatting to Simon at PowerfulUK & hopefully he will come up with a solution. Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #915694 5th Aug 2021 9:39pm
Hairy Dan
Cheers WizzardPrang, let me know what Simon comes up with if anything. Not having my car yet is a problem when trying to sort this sort of stuff out Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #915712 5th Aug 2021 11:26pm
Tim in Scotland
A reply to this has been posted on the FB All New Defender Off-road group where the owner has made a detachable ground plane plate that bolts between two of the cross bars of the expedition roof rack (could probably do it with just the cross bar system if you don’t have the full on rack) and the head unit is removable being mounted in one of the “bins” that you buy off the inter web that fit in one of the slots in the centre console.
(photos courtesy of Andy Ludford)
Some of the South African and Aussie members have mounted the antenna on a folding mount on the trailing edge of the bonnet leading the cable through one of the factory grommeted holes in the firewall back to the cabin.
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #915743 6th Aug 2021 9:20am
cyberhusky
Luxembourg
Check the video of the Gaydon Land Rover Show from Powerful UK
They show a Freelander 1 with the CB antenna mounted on the rear wheel holder.
Could be an idea for the Defender
 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #915805 6th Aug 2021 4:51pm
Hairy Dan
Thanks for the replies, couple of options to consider there. Thumbs Up These are the the RLD mounts that are for the Disco 3/4's
Photos courtesy of Martin's Disco 4 forum Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #915816 6th Aug 2021 6:28pm
WizzardPrang
Thanks for those pics. Useful for me too. Simon(PowerfulUK)'s initial idea looks similar with a plate which would double as a ground plane or to mount a mag mount & bolt to the roof rails as opposed to the cross bars. I'll let you know when I get some more info.
Also the D4 rails look similar size so that mount could work?
Thumbs Up Current vehicle: 2020 Defender 110S
Insta: wizzardprang
Post #915861 6th Aug 2021 9:51pm
Hairy Dan
I've spoken to Ray who manufactured the original brackets shown in the above photos and he is going to see if he can find a new Defender and just try the rails for size and he's going to get back to me soon Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #915870 6th Aug 2021 11:32pm
RLD
yes they fit as long as you tighten them up properly RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #915895 7th Aug 2021 10:37am
Hairy Dan
Just emailed you back Ray Bow down Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #915899 7th Aug 2021 11:04am
DaveCNB
United States
Hi All,
Just wondering if there was any contact info for RLD (tried googling w/o success) to see about getting one of their roof rail antenna (NMO?) mounts.
Thanks!
Dave
Post #945885 15th Mar 2022 8:25pm
Hairy Dan
Dave the post just above mine with username RLD is Ray, once you have 3 posts you can PM him on here and he will get back to you. The mounts are great and also fit the Disco 3/4's and is the only mount I've used on my cars. So you need 2 more posts to be able to private message Ray, so what Defender do you have? Wink Cheers Ian
Kielder 4x4 Safari
Post #945888 15th Mar 2022 8:42pm
DaveCNB
United States
Thanks Dan! Will post on my new Defender and the VHF/UHF radio install I just did yesterday.
Appreciate the response and advice.
VR,
Dave
Post #945889 15th Mar 2022 8:52pm
ESU 876
Re Ray's mounts. They will fit but the channel in the roof bars is wider than on D3/4 so positioning and tightness will be important. Ideally the the plate that sits in the channel needs to be a bit wider (33mm c/w 29mm on D3/4). I've just moved a light bar using Thule mountings and had to buy a new mounting kit to ensure fit and ease putting on and taking off. Neil
Post #947123 26th Mar 2022 5:55pm
Hairy Dan
I've had 2 of Ray's mounts fitted for a couple of months now and providing you make sure the plate is central in the roof rail they tighten up without a problem. One of mine has a big Sirio aerial attached to it which has Censored many trees when out on the green lanes and the mount is still fixed properly Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #947133 26th Mar 2022 7:18pm
Page 1 of 3 123>
