![]() | Home > General & Technical (L663) > CB Radio Aerial Mount |
ESU 876 Member Since: 26 Mar 2022 Location: Bradford Posts: 3 ![]() ![]() |
Thanks, Dan,
I think it helps that Ray's T piece is thicker than Thule's. Neatest solution that I've seen. Neil |
DaveCNB Member Since: 15 Mar 2022 Location: So. Cal Posts: 64 ![]() ![]() |
Ray was nice enough to make me a mount to fit a ¾" NMO antenna fitting and ship it out to the US.
Man he does great work, the materials, cuts/bend in the ¼" aluminum and fit and finish are top notch. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Can't wait to get it installed and the antenna mounted/wired up. Thanks again Ray, you are an artist/craftsman! |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1438 ![]() ![]() ![]() |
I'm using one of Ray's mounts and I basically have the mount fixed to the roof rails and a Sirio Turbo 5000 aerial mounted on Ray's mount, no other earth connections or anything and I have great reception and transmitting. Hope that helps
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 166 ![]() ![]() |
Thanks Ian, that's great news.
![]() Looks like I have some shopping to do. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
Thanks to Ray, I now have this:
![]() Fits perfectly. Also thanks to Hairy Dan for the info. ![]() Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
alabbar Member Since: 13 Oct 2022 Location: Dubai Posts: 5 ![]() ![]() |
thats grate
MattBW Member Since: 18 Mar 2022 Location: Warks Posts: 3 ![]() ![]() |
Hi, anyone know if Ray still makes these? They look fantastic. |
When you have 3 posts you can PM Ray
https://www.defender2.net/forum/member-rld.html Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks very much, bit of a radio enthusiast and seems the best mount was on this forum. What a lovely find this community is.
PaulM78 Member Since: 28 Jan 2022 Location: Sheffield Posts: 4 ![]() ![]() ![]() |
Looks a cracking idea, did everyone just run the coax out of the rear door, hinge side then onto the roof?
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3013 ![]() ![]() |
lt's great that CB radio is still active in the USA, it's pretty much dead here except for the truck drivers who l think may still use it.
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1259 ![]() ![]() |
OTT arial mount.
https://www.ebay.co.uk/itm/176002194673?va...gJM4vD_BwE ![]() Click image to enlarge OTT price ![]() |
cyberhusky Member Since: 09 Feb 2021 Location: Luxembourg Posts: 276 ![]() ![]() |
I run the cables for 2 antennas along the B pillars on both sides of the Defender inside the car. But that is a bad idea. As rain water is sliding along the cable wetting the rear carpet. I removed the cables and antennas now and go through the A pillar under the snorckel inside the car vis the grommit seal. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history) |
That's what I've done as it's only for occasional use, e.g. when I'm greenlaning in a group. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
