Home > Technical > Automec brake lines |
Skillo Member Since: 29 May 2019 Location: Llwydcoed Posts: 9 |
Good morning 🌞
Has anyone installed the automec brake line kit ? https://automec.co.uk/products/brake-pipe-...8731832337 The link is for a 2001 Defender….mines 2012. I checked with Automec…they don’t seem to be sure if it will fit Thank you !! |
4th Aug 2021 8:37am |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
I bought mine from a guy with an eBay store:-
https://www.ebay.co.uk/itm/304078435794?ha...SwpLlevmtu £52 for a full set. No affiliation BTW. Rgds. Chris |
4th Aug 2021 9:38am |
Thank you Pacha…
4th Aug 2021 10:27am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
Do these come ready formed or do you bend them to shape? > 110 XS Double Cab
4th Aug 2021 11:03am |
Automec state they are formed and ready to fit the 110. I’m no sure anyone here as tried it…I need to upgrade mine as it’s close to MOT failure. |
4th Aug 2021 11:53am |
That's great. Mine had a replacement set done by a garage which are a tad messy.
I don't think a TD5 set will fit TDCi however. At least that's what Pioneer advised when I enquired about the suitability of their TD5 replacement kit for my TDCi. If I remember correctly the reason was possibly to do with the ABS module > 110 XS Double Cab |
4th Aug 2021 11:58am |
I will keep trying….MOT is not due till December…..
4th Aug 2021 12:15pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5870 |
I ordered their kit about 5 years ago and pipes are still good. I think a couple of the pipes were a bit long(mainly axle) but all ends fitted and found them well made. I would use them again. 1999 Defender TD5 110
4th Aug 2021 2:13pm |
Nice. Wonder whether they will develop a TDCi kit > 110 XS Double Cab
5th Aug 2021 10:51am |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 662 |
Of course - they arrive in a 4.5M box 😉😉😉😉 They come in the right lengths with correct fittings on both ends. You have to unfurl them, straighten and then bend to shape to fit. |
6th Aug 2021 6:40am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 489 |
I would by a couple of rolls of kunifer pipe and a box of unions a flare tool and make your own that way you can copy the old ones perfectly
6th Aug 2021 9:29am |
Thank you ! |
7th Aug 2021 12:46pm |
I shall keep that in mind…thank you. |
7th Aug 2021 12:49pm |
