![]() | Home > Technical > Automec brake lines |
Skillo Member Since: 29 May 2019 Location: Llwydcoed Posts: 12 ![]() ![]() ![]() |
Good morning 🌞
Has anyone installed the automec brake line kit ? https://automec.co.uk/products/brake-pipe-...8731832337 The link is for a 2001 Defender….mines 2012. I checked with Automec…they don’t seem to be sure if it will fit ![]() Thank you !! |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
I bought mine from a guy with an eBay store:-
https://www.ebay.co.uk/itm/304078435794?ha...SwpLlevmtu £52 for a full set. No affiliation BTW. Rgds. Chris |
Thank you Pacha…
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2322 ![]() ![]() ![]() |
Do these come ready formed or do you bend them to shape? > 110 XS Double Cab
Automec state they are formed and ready to fit the 110. I’m no sure anyone here as tried it…I need to upgrade mine as it’s close to MOT failure. |
That's great. Mine had a replacement set done by a garage which are a tad messy.
I don't think a TD5 set will fit TDCi however. At least that's what Pioneer advised when I enquired about the suitability of their TD5 replacement kit for my TDCi. If I remember correctly the reason was possibly to do with the ABS module > 110 XS Double Cab |
I will keep trying….MOT is not due till December…..
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5929 ![]() ![]() ![]() |
I ordered their kit about 5 years ago and pipes are still good. I think a couple of the pipes were a bit long(mainly axle) but all ends fitted and found them well made. I would use them again. 1999 Defender TD5 110
Nice. Wonder whether they will develop a TDCi kit > 110 XS Double Cab
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 664 ![]() ![]() |
Of course - they arrive in a 4.5M box 😉😉😉😉 They come in the right lengths with correct fittings on both ends. You have to unfurl them, straighten and then bend to shape to fit. |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 507 ![]() ![]() |
I would by a couple of rolls of kunifer pipe and a box of unions a flare tool and make your own that way you can copy the old ones perfectly
Thank you ! |
I shall keep that in mind…thank you. |
