![]() | Home > Td5 > TD5 steering box leak |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5867 ![]() ![]() |
Don't know the cost, but talk to Adwest, and buy direct.
http://www.adwest-engineering.co.uk/ Andy |
highbayrack Member Since: 06 Feb 2009 Location: Northampton Posts: 31 ![]() ![]() ![]() |
Cheers Andy, that's great info
![]() Chris MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion. |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
It is possible to renew the seals.... but this tends to delay the inevitable. On my old V8 I used to slosh a cupful of brake fluid in there to make the seals swell up for the MOT, but I guess you're probably looking for less of a bodge than that
Mullen Member Since: 31 Aug 2011 Location: West midlands Posts: 93 ![]() ![]() |
I got an exchange unit for my td5 from craddocks, think it was about �200 and fitted it myself
I spoke to my local Indy about replacing the seals some time ago, he said that for the time it takes in labour charges, and never a pucker long term soloution he always only ever fits a new box which is cheaper in the long term. My problem is that we are thinking of selling the car therefore I didn't really want to spend a fortune on it. That said we've had it since new, it's done 70k miles and apart from a brake master cylinder and a handbrake cable we've not spent a penny on it apart from servicing. MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1851 ![]() ![]() ![]() |
Second the Adwest route, apparently they remachine the castings, everything else is new.
I fitted a couple of recon units to my 100" bitsa, 18months max before they leak again. Adwest 3 years and still dry. Keith |
Cheers guys, I'll give Adwest & Craddocks a call in the morning
Spoke to Adwest today (Gary) very helpfull chap. He quoted me �281 + �28 delivery on a new OEM spec box, plus fitting of course, but he says he would always recommend going down the route of a 'Seal Repalcement kit' in the first instance costing about �20 from Britpart + Labour. I could not do this job myself and I know the Indy I normally use in Rushden only wants to replace the whole box. Rang another Indy in Towcester who gave me the same old sob story saying you need specialist tools to do this job. Well I called Gary back at Adwest, he said this was total B
![]() Chris ![]() |
abomb1969 Member Since: 23 Jul 2011 Location: Welwyn, Hertfordshire Posts: 79 ![]() ![]() ![]() |
�91 here exchange http://www.mm-4x4.com/steering-145-c.asp
Can I ask a steering question. When I turn the steering at very low speeds on my TD5 I get a rubbing sound, quite loud, and it seems to be coming from the steering column. I have to get the thing up on some jacks and have a listen, I just wondered if anyone might know what it was? |
Dunno, but all mine (3) have made a groaning noise like you describe.
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
9 times out of 10 you end up replacing the steering box. TBH, as you need to remove the box to replace the seals anyway, you may as well put in a new box - Fit and forget. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
my old 300 leaked, i bought one from Adwest and fitted it, quite straightforeward.
just be careful of the unions for the hoses on top of the box, they will be very tight and a b!tch to loosen off! BM52 |
Shop around the usual suspects for the OEM box. You may be able to get it cheaper. Just insist on it being Adwest if that is what you want. I know Brookwells have them on the shelf normally.
Thanks guys, the seal option would not be in the running if we were keeping the car, but we want to trade her up to a newer model and I really didn't want to fork out �350 + on a car we are not keeping. My problem now is finding someone who will do the seals for me.
Cheers Chris MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion. |
