Home > Puma (Tdci) > Coolant hose clips… and fuel filter casing
TXH90
United Kingdom 2007 Defender 90 Puma 2.4 HT Tamar Blue
Hi all,
I’m partway through my first ever service on my 90.. ahead of my trip northerly to do the NC500 Very Happy learning plenty about maintenance as I muddle through but wondered if someone might be able to help with the muddling.
Trying to fathom how to undo the clips attached to the coolant hose so I can drain… do I need a specialist tool? (Apologies not mechanically-minded) or can I go at it with a pair of pliers… if so it looks like I’d have to replace with a new clip they’re pretty robust!
Whilst I’m here I attempted to replace the fuel filter too, but came a cropper as the bolts on the housing have seized on and the bolt appears to round when I try it, have wire brushed back and sprayed with Pen oil and will try again I guess. Suggestions… hammer a socket on and have a go? Impact gun? (Are these stupid ideas? Whistle )
Many thanks for help in advance
Tom
90 2.4
A Northumbrian south of the Humber
Post #914277 27th Jul 2021 3:48pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Hose clip pliers are your friend, example below - loads of makes and prices.
 Rgds.
Chris
Post #914280 27th Jul 2021 3:56pm
TXH90
Brilliant, thank you! Smile
Post #914281 27th Jul 2021 4:01pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Which bolts on the fuel filter ?
The cover is held on with a turn clip and the actual filter just unscrews from the housing.
Can you attach a photo ?
Kev
Post #914359 28th Jul 2021 3:42am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
A set of extended / flexible ones are great for the hard to reach hose clips.
Post #914362 28th Jul 2021 4:46am
TXH90
Kev
Hi,
Yes I was expecting that too having watched the tutorial vids, sadly its an M8 bolt holding it on pretty firmly. Hoping another go at it later after the lubricant has been at it will work. Otherwise I’ve no clue..how essential is a fuel filter renewal anyway Whistle
Tom
Post #914365 28th Jul 2021 5:18am
TXH90
Ah brilliant, as the the hose in question is right at the bottom of the engine bay this might be the one I need- many thanks for the heads up!
Tom
Post #914366 28th Jul 2021 5:19am
