Home > Puma (Tdci) > 2.2 limp mode and fault codes |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2292 |
The first two won't cause limp mode.
Third one won't cause limp, only over/underfuelling. The last two will and look to be an issue with the turbo actuator or variable turbo geometry vanes. I have read that the actuator wiring can chafe/wear through near the connector so check there first. If all ok, disconnect the rod between actuator to turbo (remove one c-clip - be careful not to lose it!) then start the engine and see whether the turbo actuator (black box) motor wiggles back and forth. Give it a prod and it should try to return to centre. If that seems ok feel the rod/lever at the turbo end to feel for smoothness of operation. If it's notchy/sticky then you have internal turbo issues. > 110 XS Double Cab |
1st Jul 2021 1:06pm |
You can see in this video the actuator is trying to act and move the rod but there is resistance at the turbo end meaning the actuator/rod cannot move. You want to check that both actuator and turbo end can move freely
> 110 XS Double Cab |
1st Jul 2021 1:16pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Many thanks for the suggestions. Will pass them on. Much appreciated. 2005 Td5 | 90 Station Wagon | Tonga Green
1st Jul 2021 9:07pm |
