Home > My Defender > My USW
Page 34 of 37 <123 ... 3334 353637>
22900013A
In order to fit a replacement mud flap I removed the old one but the inner rivnut is spinning, so I can't get the bolt out. I've tried pliers, wedging a spanner on - any ideas?
 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #908610 20th Jun 2021 9:49am
Bluest
Can you get some pliers or grips up inside the outrigger to grab the back of the rivnut? 2007 110 TDCi Station Wagon XS
Post #908613 20th Jun 2021 10:44am
22900013A
Yeah I tried that, can't get enough pressure on them to hold it. Might just have to cut the bolt off. :/ 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #908616 20th Jun 2021 11:17am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Re tighten the rivnut as you would when installing it.
Failing that I've jammed a screwdriver behind the flange to get the bolt removed
Post #908713 21st Jun 2021 7:32am
22900013A
I didn't install them, and it just spins either way? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #908732 21st Jun 2021 8:30am
22900013A
As my 110 approaches 100,000 miles it has developed a couple of niggles. Yesterday I got really bad rev hang, which it has never done too much before. This was really obvious and made it a bit of a pain to change gear. Turning the ignition off and on again seemed to cure it.
My headlamps developed a strange feature. When putting low beam on the blue main beam light would glow dimly, brightening up when going to full beam. When i got to my mother's house i asked her to operate the switches so i could see what the lights were doing. They operated normally and,the dash light was back to normal.
I've also got a sort of low howl coming from the back of the vehicle when running, wheel bearing or diff?
Any ideas? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #914398 28th Jul 2021 8:18am
I'd probably look at the clutch switch for the rev hang problem and the light switch for the high beam indicator.
The low howl has realistically got to be either a wheel bearing or diff but couldn't say which one. Perhaps drain the diff oil and see if that suggests anything? Darren
Post #914405 28th Jul 2021 8:56am
22900013A
Thanks, at least give me something to go on. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #914430 28th Jul 2021 12:40pm
22900013A
 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #914747 30th Jul 2021 12:13pm
22900013A
So I had a set of 569203 (often, incorrectly, termed IIB rims) and realised my Michelin 7.50R16s could be run with tubes...! So here it is! Now I must confess I'm a little dissapointed, one as the rear wheels make very slight contact with the brake caliper. The tyre place have ground the wheels slightly but it's still catching on cornering. Secondly the handling is woeful, steering is now really twitchy and it feels too light in the tail end. Very bad steering wobble over 55mph. I'm hoping balancing will help, but seriously considering just cutting my losses and going back to standard rims. Does look the absolute dogs though. Thoughts?
 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #931898 30th Nov 2021 4:40pm
CarMan
+1 for the looks Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #931900 30th Nov 2021 4:50pm
22900013A
Yeah looks epic but a bit worried about ending up in a ditch... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #931901 30th Nov 2021 5:00pm
L110CDL
They do look good though, what offset are they please ? 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #932900 8th Dec 2021 9:16pm
I think the only way to run Series-type rivetted tube-type rims on a disc-barked Defender is to fit wheel spacers, there is insufficient clearance otherwise.
On one occasions when I was rotating the tyres on my 2007 DC I grabbed a Series rim of my pile of spares and fitted it with a couple of nuts, simply to hold up one corner while I moved the take-off wheel to the next corner. It clonked on the brakes many times during one revolution (and initially I thought I found a broken diff - then I realised what was happening).
If you want this style of rim I strongly suggest using the Nakatanenga "look-alike" which fits perfectly and is TUV and type approved.
Post #932940 9th Dec 2021 8:41am
22900013A
I decided just to take them off and go back to standard wheels, now runs just as nicely as it did before. Oh well, we live and learn...
Had it put spacers on the wheels would be outside the wheelarches so probably illegal. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #942328 13th Feb 2022 3:44pm
