Home > Puma (Tdci) > Over revving on gearchange
Slrealm
United Kingdom 2007 Defender 90 Puma 2.4 CSW Tonga Green
Hello, can anyone help me please with an issue on my Defender? It's a 2007 2.4 TDCI with very low miles. Some months ago it started flaring the revs when I change gear before they drop away. The brake light fuse is fine, I've tested the clutch sensor switch and it's working perfectly too. It only does it when driving, if I raise the revs standing still and snap close the throttle the revs drop away immediately. Had a diagnostic done, no fault codes. Can anyone suggest anything please?
Thank you in advance, Steve.
Post #905898 31st May 2021 10:32pm
Still sounds most likely the clutch switch, bypass it which on a Puma means so can simply make a wire loop to create a closed circuit. You cannot just unplug it like a TD5.
The connectors are 2 pole J.P.T. Connectors.
Beyond that VCV issues, then EGR, MAF & MAP Sensors. Most of these with the exception of the VCV do flag up codes though.
In your case I would concentrate mostly on clutch switch no1 and VCV no 2 with those symptoms. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #905903 31st May 2021 11:07pm
Slrealm
Thanks custom90steve,
I should have said I've already looped the clutch sensor and made no difference. Hadn't considered the VCV though so that's my next intended victim. Thanks for the advice. Thumbs Up
Post #905911 31st May 2021 11:22pm
