Home > Puma (Tdci) > Corroded/melted terminal leading to glow plugs |
Andy T Member Since: 25 Aug 2017 Location: Bucks Posts: 230 |
This is my 2.4 Puma 110 Commercial that, amazingly, starts first time every time! Hopefully these pics demonstrate a somewhat(!) corroded and semi-melted junction with a wire in at the bottom and out at the top, and it looks to me like it won't be a reliable starter for long.
I'm presuming that the nut holding the spade connector won't budge and may need grinding off. If I then replace the spade connector, does anyone know if replacement blocks are available to reconnect please? My 2.2 Puma and TD5 have different set-ups for the glow plugs, so I've nothing obvious to work from, and I'm a relative novice so will be grateful for advice Cheers Andy Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2011 2.4 White 110 CSW LHD 1998 300TDi Wolf TUM 2015 2.2 Corris Grey 90 2009 2.4 Alaska White 110 Commercial - gone 2006 TD5 Barolo Black 90 - gone 1995 TD5 Green 90 - gone 1984 2.25 Marine Blue 88 |
29th May 2021 12:06pm |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Soak it in WD40 or similar product for a few days, give it a few taps to break the rust seal and it may come off. If not try a bit heat (if safely away from fuel etc) to expand the metal slightly. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
30th May 2021 8:42am |
Cheers Jeffersj and dorsetsmith, really helpful. Once sorted I'll post another pic 2011 2.4 White 110 CSW LHD
31st May 2021 11:48am |
"C3355 is a tin plated, eyelet connector with up to 1 wired pins. The connector's location is LH side of engine. Its part of the Engine Harness loom and its part number is YPG10012. This connector was used in 2007, 2008, 2009, 2010 and 2011 models of Defender"
Lrparts.net have the harness LR004840 and screws LR004500 Cheers Andy 2011 2.4 White 110 CSW LHD 1998 300TDi Wolf TUM 2015 2.2 Corris Grey 90 2009 2.4 Alaska White 110 Commercial - gone 2006 TD5 Barolo Black 90 - gone 1995 TD5 Green 90 - gone 1984 2.25 Marine Blue 88 |
31st May 2021 12:17pm |
22nd Jun 2021 2:53pm |
