Home > Puma (Tdci) > Corroded/melted terminal leading to glow plugs
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
This is my 2.4 Puma 110 Commercial that, amazingly, starts first time every time! Hopefully these pics demonstrate a somewhat(!) corroded and semi-melted junction with a wire in at the bottom and out at the top, and it looks to me like it won't be a reliable starter for long.
I'm presuming that the nut holding the spade connector won't budge and may need grinding off. If I then replace the spade connector, does anyone know if replacement blocks are available to reconnect please?
My 2.2 Puma and TD5 have different set-ups for the glow plugs, so I've nothing obvious to work from, and I'm a relative novice so will be grateful for advice
Andy
 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM
2015 2.2 Corris Grey 90
2009 2.4 Alaska White 110 Commercial - gone
2006 TD5 Barolo Black 90 - gone
1995 TD5 Green 90 - gone
1984 2.25 Marine Blue 88
Post #905613 29th May 2021 12:06pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Soak it in WD40 or similar product for a few days, give it a few taps to break the rust seal and it may come off. If not try a bit heat (if safely away from fuel etc) to expand the metal slightly. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #905699 30th May 2021 8:42am
dorsetsmith
Brown and blue 6mm wire between C3355 ------------------------ C1039-1 plug at rear engine looks badly damage and will need to be replead or replaced-------------- red Red 6mm wire that go from C3355 to your glow plug may also need replacing-------LR004840
Glow plug wiring harness and has the terminal post with it
Good idea inspect engine wiring loom heat damage as glow wire has got hot enough melt wiring insulation
Post #905710 30th May 2021 10:00am
Andy T
Cheers Jeffersj and dorsetsmith, really helpful. Once sorted I'll post another pic 2011 2.4 White 110 CSW LHD
Post #905830 31st May 2021 11:48am
Andy T
Does anyone know where I can source part YPG10012 please?
"C3355 is a tin plated, eyelet connector with up to 1 wired pins. The connector's location is LH side of engine. Its part of the Engine Harness loom and its part number is YPG10012. This connector was used in 2007, 2008, 2009, 2010 and 2011 models of Defender"
Lrparts.net have the harness LR004840 and screws LR004500
Andy 2011 2.4 White 110 CSW LHD
Post #905837 31st May 2021 12:17pm
Andy T
Happy ending!
Post #908960 22nd Jun 2021 2:53pm
