![]() | Home > Td5 > Cruise control |
FD7 Member Since: 16 Feb 2021 Location: Midland Posts: 178 ![]() ![]() |
I didn't think I needed this, but thats so darn neat and tidy, I think I have too look at it!
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
These ones: https://www.ebay.co.uk/itm/141454793794 |
Simmo107 Member Since: 06 May 2021 Location: Birmingham Posts: 12 ![]() ![]() |
Could this be done on any age defender td5? Would love to give this a go haha!
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Yup. Works on any year TD5 defender.
If youve altered the gearing at all you need a speedo healer or have the ECU reprogrammed to suit the new ratios. Instagram @defender_ventures Empire Tuning - Agent |
Daniele Member Since: 10 May 2021 Location: Torino Posts: 3 ![]() ![]() ![]() |
Hi All!
I installed the harness on my '99 TD5 with ECU MSB101170. The wiring works, the NANOCOM detects that the Cruise Control is present and switched on. It also ecognize when i press the 2 buttons. The problem is that the Cruise control does not work (even though the LED and the indication on the NANOCOM come on). I encountered one thing I'd like to hear from you: The clutch contact is not detected by the NANOCOM (the contact works, I have tested it up to the ECU connector) and the NANOCOM constantly detects the Clutch Switch OFF. Could this be it? What do you advise me to check? Thanks a lot! |
Could mean the ratios are off and you may need a speedo healer.
Also only works above 50kmh Instagram @defender_ventures Empire Tuning - Agent |
Thanks for the answer!
I tried to drive fast, but nothing happen... What do you mean with "ratio are off"? |
CC will only work if the gear ratios are as they left factory. I believe even tyre size can play a part.
It does take around 5 seconds+ to actually kick in sometimes Instagram @defender_ventures Empire Tuning - Agent |
Understand. I never touch the ratio and the tyres are the standard 7.50 r16
Diffs, and tyres do not make any difference. The revs and the speedsensor signal have to be right. Keep pushing the speed up with a constant throttle and you will feel it takes over. Then you can take your foot of the throttle. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I've just added Cruise Control to my Td5 and found the wiring diagrams commonly available online somewhat misleading. There is no need to touch the ECU pin used for the clutch switch indication as implied by other diagrams, so I've modified the one I found most useful to show what actually worked for me:
![]() Click image to enlarge None of my other vehicles have a cruise control master switch so I omitted that from the Defender installation. Cruise disengages if you touch the brake or clutch pedal or activate the Resume switch. One question though - the Nanocom documentation mentions this: "Cruise Lamp: The TD5 ECU has been designed to work with a wide range of possible fitments and options. Many of the input sensors and output controls can be omitted giving many vehicle option, model or market variants. This value indicates if this TD5 ECU has been programmed to drive a cruise control warning lamp in the instrument cluster or not, This should not be confused with the cruise control master on off switch lamp which merely indicates power being applied to the cruise control system." As I've got a few spare wires in the multicore used to connect the Set/Res switch (from a Discovery 2 as pictured earlier in this thread) I was wondering if it was possible to fit a "cruise active" LED. However, I don't see any dedicated ECU pin for that purpose so is the extract above referring to a code that the Nanocom can read via the ODB port? Regardless, for a total spend of ~£30 I'm pretty happy with this upgrade. It was even possible to install the wiring from the steering column housing to the ECU without removing the dashboard, so that was a bonus ![]() |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
Can something similar be achieved on TDCi? > 110 XS Double Cab
@hank - see https://www.defender2.net/forum/topic43319.html i.e. Yes, but for about 10x the price
Thanks intercept. I’ve seen the aftermarket kits but wondered if there’s functionality in the factory ECU like on td5’s that could be exploited with relative ease > 110 XS Double Cab
