Home > Technical > Extender Warranty 2016 MY Defender.
m33ufo
Wales
Hoping for some feedback.
2016MY Defender - 13K miles - LR Extended Warranty
Over the last few drives I've noticed a barely perceptible "rattle" from cold when in neutral. This disappears as soon as the clutch is depressed or after 15/20 minutes once it's warmed up. In all honesty it's probably always been there but curious if anyone has anything similar?
Cheers Gents Thumbs Up 110 DCPU
Mark
Post #899848 24th Apr 2021 2:12pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I had similar on my 2015 2.2 at 6000 miles.
Dealer fixed it very quickly and easily.
I could “ play” the noise with the clutch pedal.
Maybe yours is the same?
Described as “ thrust bearing”.
Some say “ release bearing”
It’s common. Many Defenders do 1000s miles with this bearing noise.
Clemmo👍 Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #899872 24th Apr 2021 4:38pm
LR90XS2011
search clutch rattle
there is loads of threads on here about it, the springs in the clutch plate become loose as there is no DMF DEFENDER 90 TDCI XS,
Post #899880 24th Apr 2021 5:57pm
m33ufo
Wales
Clemmo👍
Thanks for the feedback.
Do you think this might be covered via the extended warranty? 110 DCPU
Mark
Post #899893 24th Apr 2021 9:17pm
m33ufo
Wales
Cheers. I have read a few threads on the topic. Was particularly interested in whether this problem would or would not be covered by extended warranty?
Thanks. 110 DCPU
Mark
Post #899894 24th Apr 2021 9:19pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
If it’s the clutch they may just say it’s a wear item, like brake pads
Best to check the document with the warranty to be sure Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #899896 24th Apr 2021 10:08pm
m33ufo
Wales
I believe the clutch spring issue has been covered during the original warranty period, but unsure about extended warranty. Seems to be a recognised problem.
Thumbs Up 110 DCPU
Mark
Post #899899 24th Apr 2021 10:15pm
LR90XS2011
Mine was replaced at 11000 miles at 4 years old along with the adaptor shaft, but I did have an e/mail that proved I had moaned about it at less then 3 years old and the dealer had said it was normal, the LR rep on here helped me get it done FOC at another dealers DEFENDER 90 TDCI XS,
Post #899903 25th Apr 2021 5:24am
m33ufo
Wales
Thanks Thumbs Up
After a brief chat it ooks like it will be covered via extended warranty, assuming no wear and tear. Of course if there is wear and tear then I'll have to cover the gearbox removal and reinstatement. The labour cost, £1080 Rolling with laughter 110 DCPU
Mark
Post #899911 25th Apr 2021 7:40am
