Home > My Defender > Puma to LT1/8L90 Restomod |
mrfirepro Member Since: 06 Nov 2020 Location: kent Posts: 231 |
got to the bottom of the rear ABS sensor, this is the bush that is needed, costs more that both the sensors
Click image to enlarge Still not recieved the brake parts, but have received the air suspension (minus rear bags) Click image to enlarge now got quite a bit of work to be getting on with, hopefully things should move a bit faster now. Matt - I'd be pleased with 12mpg, 180/200 miles a tank I wouldnt bother with another tank, thanks for the info. |
9th Apr 2021 7:19pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
Ooh nice bits!! Keeping the mail man busy!!
Crazy the bush costs more then the sensor! Can't wait to see this running! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
9th Apr 2021 7:29pm |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 399 |
What air kit did you go with in the end? Doesn’t look like the VB kit I thought you were going with?
10th Apr 2021 8:49am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 486 |
Looks good which air kit did you go for? After years of poo booing the idea I finally started fitting fuel pump/sender hatches in the rear floor. My god what a improvement it can be done factory spec with a captive ring under the floor and a almost flush fitting cover on top. This really should of been factory fit it makes a fuel pump swap a ten minute exercise with no fuel draining etc
10th Apr 2021 10:12am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3683 |
Is 12mpg really all you can expect? I know it will never be economic, but I was hoping to see something closer to 20. Wishful thinking?
10th Apr 2021 11:24am |
Thanks guys.
Matt, thanks - I looked at fitting the fuel tank support the other way round as it makes total sense and I had the same thought as you, but unless I'm missing something (nothing new there) I'd need to grind off the captive nuts and nut and bolt it. I'll revisit this. I do like a bit of EM121, I'll give the steering box a go over with it the next time I mix some up, did wonder as the finished looks dodgy. question - The upper panhard rod to chassis mounting bracket has a massive hole in where the tie bar connects to it, I don’t remember any bush or anything, I've looked at a few diagrams but there doesn’t seem to be any bush, am I missing something???? or is that just the way it is as it seems very odd..... The air suspension was this kit http://onairsuspension.uk/passenger-vehicl...exc_shocks I was going with the VB kit but with the exception of IRB no one would supply and commission the kit despite me talking with every UK agent, was a good move in the end, the onair stuff is a LOT cheaper and the qulity seems really good, Juice motors have a good video on you tube of one being fitted. Keep the advice coming it's a really big help. |
11th Apr 2021 9:19pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3785 |
With the red engine cover, that looks like the supercharged LSA engine in there,...430KW or around 570/580hp,...very nice. Pickles. |
11th Apr 2021 10:43pm |
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 517 |
mrfirepro, first off nice build!
Popping my 130 on bags myself and wondering what sized fittings and line your kit supplied? Couldn't find it on their site. I ask as I'm torn on which Airlift 3P controller to purchase, the 1/4" or 3/8" variant. Would be nice to know as I'd have something to compare visually with Juice's videos regarding inflation speed as the 3/8" lines will allow a flow rate of 225% compared to that of the 1/4" (71.3 mm^2 vs. 31.7 mm^2, respectively). Cheers Stuart Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
11th Apr 2021 11:17pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2642 |
My naturally aspirated v8 estate doesn't get more than 22 mpg combined - and that's 80% having it in 'comfort' setting pottering around. My V12 does better on a run then again its only rear wheel drive. I can really imagine a v8 defender being sub 15mpg. |
12th Apr 2021 7:48am |
Cheers Liam, so you’re saying I should go for a V12 instead?!!
12th Apr 2021 9:20am |
Well, driven in anger it's worse but on a run does better.
12th Apr 2021 9:26am |
The big hole is all you have on the Panhard rod bracket the stay is just to help sideways motion, make sure to use the correct large thick washer and UNF locknut
12th Apr 2021 9:49am |
I've been thinking about the fuel tank craddle and refitting it so that it can be removed downwards (thanks to Matts comments ) if I do this is it really possible to remove the tank from below given the fuel lines and electrical connections?
13th Apr 2021 8:05am |
Yes you can. This is what I have done. You can drop the tank enough to comfortably release the fuel lines from the pump.
There is a bit of detail about what I did about half way down this page: https://www.defender2.net/forum/topic67542-255.html |
13th Apr 2021 8:24am |
