Home > Technical > Fuel gauge not moving
Page 2 of 3 <123>
james.works
France
The sender unit is also new, just checked with the guy that fitted the new engine.
Tank was filled and has done around 150kms since.
How do I check for resitance?
Thanks
Post #897482 11th Apr 2021 4:22pm
dorsetsmith
at instrument cluster plug with meter set resistance and probes one pin 31 green - orange wire and other one pin 8 yellow -
purple wire
reading ?
Post #897498 11th Apr 2021 4:47pm
Davy
Ireland
I’ve had a wire break off at the solder joint in the fuel pump. Giving me an empty all the time reading pump out and fault was clear to see
Post #897514 11th Apr 2021 5:46pm
james.works
France
I get 491 ohms
Post #897615 12th Apr 2021 6:05am
dorsetsmith
491 ohms = fuel tank empty
The fuel tank sender is saying that tank is empty
had wrong sender spec Embarassed so 491 ohms = 1/2 tank of fuel prox
Post #897624 12th Apr 2021 7:03am
james.works
France
Interesting, definetely not an empty tank though, there's at least 40 litres in there.
So a lower resistance would indicate more fuel, is that correct?
I've just plugged the instrument panel back in and it's working! Although showing only a quarter tank full which I doubt, I'll fill it and see what happens.
So I'm guessing a corroded pin or something.
Post #897628 12th Apr 2021 7:19am
dorsetsmith
So a lower resistance would indicate more fuel, is that correct? yes
need to see if resistance changes with fuel level in the tank ?
Post #897631 12th Apr 2021 7:27am
Martin
Site Admin
2.2 spec senders are 50 Ohms full 1000 Ohms empty.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #897635 12th Apr 2021 7:39am
dorsetsmith
Exclamation
That`s interesting means my sender spec not from 2.2 110 hm Confused but sender arm from 110 2013 my problem not your Exclamation hm
Idea sender arm fitted to wrong tank unit now as per martin spec
Post #897638 12th Apr 2021 7:41am
dorsetsmith
So gauge is reading 1/4 tank but sender resistance reading indicates 1/2 tank proz
try this with instrument cluster plugged in and power up move the wiring attached plug around and see if the fuel reading changes ?
1. if so cracked solder joints between PCB and pins
2. DC voltage reading at instrument cluster plug pin 1 ( + )----and---- pin 17-( - ) battery in to instrument cluster and
DC voltage reading at instrument cluster plug pin 2 ( + )----and---- pin 17-( - ) ign input to instrument cluster readings with engine running
Post #897686 12th Apr 2021 11:05am
dorsetsmith
Post #897765 12th Apr 2021 5:55pm
james.works
France
Thanks, I'll get to this asap. Update - Filled up yesterday, took 30 litres, gauge didn't move, still on 1/4 tank.
Post #897876 13th Apr 2021 6:40am
dorsetsmith
Has sender resistance value lowered Question
Post #897946 13th Apr 2021 10:56am
james.works
France
No, 488ohms at the instrument panel and 484 at the sender.
Post #898213 14th Apr 2021 3:03pm
james.works
France
Does this absolutley isolate the fault to the sender unit?
Post #898346 15th Apr 2021 6:42am
Page 2 of 3 <123>
