Home > Tdi > Blue smoke on start up after Cam belt change |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Recently had service and MOT and at the same time I had the Cam belt renewed. Since then motor has stood fo a week or so at a time without moving, but on first start up after the change I had clouds of blue smoke which cleared after a short run.
I thought it was just the possibility of excess oil being about after the work that was done and the non moving but each time on start up I am having the same problem (although the motor is standing for a week or so without moving). I did not have any smoke up on start before the cam belt change so could the timing be out or something else stemming from that or is it just coincidence? Engine is 300Tdi Jeff Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
24th Mar 2021 9:08am |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 814 |
Sorry got my terminology wrong. Not the fuel idle screw, it's known as the 'smoke screw'.
https://forums.lr4x4.com/topic/31-how-to-i...200300tdi/ |
24th Mar 2021 10:49am |
At first I thought it was a bit sluggish but not so marked, a trusted indie did the work but that was my first thought that it was something to do with the timing. Jeff
24th Mar 2021 12:15pm |
More sluggish than normal when cold?
I'd take it back and ask them to recheck the timing in view of the new smoking and change in performance. It isn't a big job to check it, they don't have to remove the timing belt cover to do it. |
24th Mar 2021 12:31pm |
Thanks for the confirmation, have booked it back in for a check. Jeff
24th Mar 2021 3:46pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
Defo timing 1951 80" S1 2.0
24th Mar 2021 7:08pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8061 |
Does it take more turns than normal to start? Sounds like FiP timing is out. Can be adjusted through font end cover. Or belt out a tooth. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
24th Mar 2021 8:10pm |
I have not heard of this one before, very underhand. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
24th Mar 2021 8:11pm |
No it starts immediately, battery kept tip top with a Ctek charger. Jeff Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
25th Mar 2021 9:17am |
from description sounds like unburnt fuel and hence timing is out, assuming it never did it before.
starting 1st turn is good for any LR (!) timing can still be out though. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Mar 2021 9:57am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5192 |
yeah that sounds like its timing to me, I would take it back to who ever did the belt, and say you want this rechecking. just in case something has moved.
I had garages cock up timings on me before, cost be a fortune, my dad ended up taking it to a tuning place to have it checked over. After the second garage cocked it up. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
1st Apr 2021 1:16am |
Thanks all, booked in for the 8th. Jeff
1st Apr 2021 8:32am |
how did you get on? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
7th May 2021 1:29am |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
I agree with most of the posts here it does sound like something isn’t timed up from the recent work, but it’s the blue smoke that’s confusing because unburnt fuel passing through would produce white smoke whereas over fuelling would be black smoke
Blue smoke would be from burning oil which doesn’t indicate an out of timing issue. Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
7th May 2021 4:52am |
