Home > Tdi > Blue smoke on start up after Cam belt change |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6098 |
^^^ Worn valve guides/seals maybe?
7th May 2021 6:48am |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Update - timing was correct but Fuel injection pump had to be tweaked to avoid the blue smoke BUT this was because the glow plugs were not connected at all! In fact one was missing with the hole sealed, 2 were intact and the last one had been snapped in place. The wiring to the plugs was in place but went nowhere, the relay/control unit isjust no lead to the plugs. connected and fitted to the bulkhead as normal
You might be asking how did I not know, well this vehicle was rebuilt in 2012 by previous owner. I bought it in 2015 immediatley set about sound proofing with and engine blanket so the engine has been covered up. No warning bulb in the panel so did not even notice. Previous owner had been a REME mechanic and I kow that army vehicles often do not have glow plugs. I have never had troubled starting, starts first turn but it is garaged overnight. Since everything is fine I am leaving well alone, but the answer will be to remove cylinder head and drill glow plugs out or replace cylinder head and glow plugs. Jeff Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 Last edited by jeffersj on 9th May 2021 7:31am. Edited 2 times in total |
7th May 2021 7:44am |
