Home > General & Technical (L663) > Clearview Camera Shark Fin Antenna
Be careful out there, seems a few have forgotten the few extra inches above the roofline:
Post #894838 30th Mar 2021 7:06am
J77
Definitely something to watch, though I didn’t option the clearsight camera, so might be a bit cheaper if I do forget. One car park I do use my 90 definitely won’t fit under the barrier, even if I took air suspension it would be touch and go. 24MY 90 D250 HSE, Tasman Blue
Post #894891 30th Mar 2021 11:24am
SN
having a rack or bars provides the relevant protection to the antenna (though theimpact of a hit will be much larger Rolling Eyes )
I know a 2.0m height limit means I will have to be in access mode to get under it going forwards - I'm probably going to go do a trial run at the local time during a quiet period to be certain! Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #894896 30th Mar 2021 11:38am
DSL
That damage looks like it just needs a little bit of superglue. Thumbs Up
Carefully of course. Whistle
Post #894904 30th Mar 2021 12:20pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
Been there got the t shirt 👕
Before:-
After:-
It was transporter damage, got an extra years warranty compensation
Post #894915 30th Mar 2021 12:53pm
markb110
Perhaps the Clearsite camera needs to point forwards...... Whistle
Post #894947 30th Mar 2021 3:57pm
Sepp
Germany
Been thinking about this before as I paid dearly already, too.
https://www.defender2.net/forum/post882466.html#882466
Post #894952 30th Mar 2021 4:23pm
Or if there was a vertical red bar showing your height limit in the mirror
Or would wade sensors turned upside down give you sky sensors?
Post #894959 30th Mar 2021 5:06pm
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
did exactly that last year with my shark fin, ended up with new roof !! but i must say NFU were brilliant and just said get ir done
Post #894964 30th Mar 2021 5:34pm
TRGRichie
Rolling with laughter
Post #894974 30th Mar 2021 6:29pm
Tricky C
did you get the casing sorted for your clear site camera in the end.
got the same issue with mine, been quoted £180 inc vat because you need the whole casing and £600 for 3 hours labour to fit. seems a bit excessive to me when all i need is the top part of the casing, so labour should be about 5 minutes. did you buy the case and fit it yourself in the end.
Post #1023141 31st Jan 2024 7:23pm
lightning
£200 per hour
l am in the wrong trade.
Post #1023149 31st Jan 2024 8:50pm
WizzardPrang
PowerfulUK do some dummy shark fins, maybe one could be cannibalised to fit? Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1023158 31st Jan 2024 10:22pm
Ronnieh
Been there and done it I'm afraid on my own garage door! £25 from Powerfuluk fixed it. Smile 2023 X Dynamic HSE 90 D250 MY24, Air suspension, HUD, Clear sight, Electric tow bar
Santorini Black
Post #1027306 8th Mar 2024 5:37pm
Blake
United States
Removing Shark Fin Camera Cover
Does anyone have a tip or tool to remove the existing rearview mirror camera cover/shark fin on my 2021 Defender 110 from the outside (vs. removing the headliner inside cab)? I can see the brackets inside cover, but I cannot pop them out. Thanks in advance!
Post #1038304 24th Jun 2024 8:12pm
