![]() | Home > General & Technical (L663) > Clearview Camera Shark Fin Antenna |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3461 ![]() ![]() |
Definitely something to watch, though I didn’t option the clearsight camera, so might be a bit cheaper if I do forget. One car park I do use my 90 definitely won’t fit under the barrier, even if I took air suspension it would be touch and go. 24MY 90 D250 HSE, Tasman Blue
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
having a rack or bars provides the relevant protection to the antenna (though theimpact of a hit will be much larger
![]() I know a 2.0m height limit means I will have to be in access mode to get under it going forwards - I'm probably going to go do a trial run at the local time during a quiet period to be certain! Steve N | 21MY Defender ![]() ![]() ![]() |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
That damage looks like it just needs a little bit of superglue.
![]() Carefully of course. ![]() |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Been there got the t shirt 👕
Before:- ![]() Click image to enlarge After:- ![]() Click image to enlarge It was transporter damage, got an extra years warranty compensation |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2664 ![]() ![]() ![]() |
Perhaps the Clearsite camera needs to point forwards......
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
Been thinking about this before as I paid dearly already, too.
https://www.defender2.net/forum/post882466.html#882466 |
Or if there was a vertical red bar showing your height limit in the mirror ![]() Click image to enlarge Or would wade sensors turned upside down give you sky sensors? |
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 ![]() ![]() ![]() |
did exactly that last year with my shark fin, ended up with new roof !! but i must say NFU were brilliant and just said get ir done
TRGRichie Member Since: 03 Mar 2021 Location: Yorkshire Posts: 180 ![]() ![]() |
Tricky C Member Since: 31 Jan 2024 Location: West Midlands Posts: 1 ![]() ![]() |
did you get the casing sorted for your clear site camera in the end.
got the same issue with mine, been quoted £180 inc vat because you need the whole casing and £600 for 3 hours labour to fit. seems a bit excessive to me when all i need is the top part of the casing, so labour should be about 5 minutes. did you buy the case and fit it yourself in the end. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3071 ![]() ![]() |
£200 per hour
l am in the wrong trade. |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 168 ![]() ![]() |
PowerfulUK do some dummy shark fins, maybe one could be cannibalised to fit? Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
Ronnieh Member Since: 05 Jul 2023 Location: Lancashire Posts: 7 ![]() ![]() |
Been there and done it I'm afraid on my own garage door! £25 from Powerfuluk fixed it.
![]() Santorini Black |
Blake Member Since: 24 Jun 2024 Location: Texas Posts: 2 ![]() ![]() |
Does anyone have a tip or tool to remove the existing rearview mirror camera cover/shark fin on my 2021 Defender 110 from the outside (vs. removing the headliner inside cab)? I can see the brackets inside cover, but I cannot pop them out. Thanks in advance!
