![]() | Home > Td5 > Yes or No? Terrafirma Big Bore Exhaust Tail Pipe |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Talk to these boys. I did
![]() ![]() https://demandengineering.co.uk/ You may be able to buy section by section as you can afford. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Diesels dont need back pressure in the same way some petrols do.
The exhuast sounds good but just like everything else TF the steel used is VERY low quality i had rust/pitting after winter then finall blew thru a few weeks later. Granted i do quite high mileage (350m+ a week) but still expected more than 8 months and one winter from it. This is mine with a decat, stainless "bullet" mid box and a 3" rear box. https://youtube.com/shorts/rmPgV5XBh9Y Now has a 3" downpipe as well. Instagram @defender_ventures Empire Tuning - Agent |
What do you want from an exhaust? If it’s free reving and more noise remove the cat. The cat makes a huge difference, unlike the tiny rear box that doesn’t really do much. |
If you want to try a decat pipe on, and want a cheap one let me know. Removed mine yesterday to swap across to a Demand system.
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5235 ![]() ![]() |
Decat on diesel is a must, My 306 HDI has rocked with out a cat for nearly 12 years. It made the turbo spool quicker and its a lot more free to rev too. After my pal drove 306 after the cat was removed, the 1st thing he did to his diesels was to remove the cats. He drove the 306 the very 1st day after i bought it, so he knew the improvements. Also My 300 TDI was lot more happier with out the CAT, But for the love of money buy a decent exhaust system, if you are going for the full smash.
Brit part and Terrafirma don't cut the mustard with me, Ok for a quick MOT fix. Brit part stuff i had to replace with in a year, and Terrrafirma suspension was better than what i had on the 300 tdi, and looked like it had been the car for 10 years, with in a matter of weeks. ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
