![]() | Home > Faults & Fixes (L663) > Interior lights |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 856 ![]() ![]() ![]() |
Scrumps, which dealership do you use? Bristol or Taunton?
Jim |
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 108 ![]() ![]() ![]() |
Jim,
The other Somerset one. We’re on our 11th out of 15 LR’s from the same dealer, 8 from the same salesman. They look after us really well. Bad experiences @ Taunton Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Hi,
Update from the master tech:- The issue with the interior lights and mood lighting is that the BCM is seeing a short to ground somewhere on the circuit so it shuts it down to prevent damage or burnt out modules. I’ve isolated this down to the roof harness and then narrowed further to the loom above the vanity lights, I’ve had to lower the headlining for access (but not remove). I’ve repaired the harness which seems to have brought the functionality back of the lights. Looking good for return today😀👍 Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
Thanks for the update....
Good News... Seems a competent dealer... You need to share... so we can all go there when we have trouble.. |
Simon,
Sorry, no can do.😀 It’s taken years of buying cars from them to build up a “relationship”. They know my background and the quality of work I do for myself so they know the standards I expect from them. See below for a recent project! Scrumps ![]() Click image to enlarge ![]() Click image to enlarge 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Is your mechanic part of a JLR dealership or independent?
Digger,
Full franchised dealership. They always allocate the Master Tech to our cars. As a retired engineer, I tend to diagnose problems before I bother them so they treat us quite well and crack-on and fix things. In all the cars we’ve had I’ve never been without transport (one way or the other). When SWMBO broke a valve stem on a wheel of her D5 she phoned the dealer and they organised LRA and phoned her every 20mins till they arrived to check she was OK. Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
