Home > Maintenance & Modifications > I have cut something off I shouldn't have....HELP! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
Panhard rod brackets on the offside, two bolts:
FC112246 - (1/2UNF X 4.3/4") From the 2007 on parts catalogue, and, yes, they really are UNF bolts on a 21st century vehicle! Since the panhard rod is only fixed to the chassis at the offside, it is probable that the bolts on the nearside only held your steering guard. |
16th Mar 2021 6:00pm |
MarcusM Member Since: 29 Jan 2020 Location: Nottingham Posts: 101 |
This is amazingly helpful- thanks BlackWolf really appreciate it Keswick green 2007 Defender 90 TD5
16th Mar 2021 8:03pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 623 |
They aren’t UNF, they are M12 starting from two years into the 21st century. |
17th Mar 2021 5:59am |
They aren’t UNF, they are M12 starting from two years into the 21st century. o no they are not
17th Mar 2021 7:04am |
As noted in my post, I am just quoting the parts list. This clearly states the numbers I gave as applicable to 2007 on vehicles, those part numbers are UNF.
To resolve this I have just had a look at my 2007 2.4 110 and the Panhard rod bracket bolts are definitely 1/2" UNF, confirmed both by bolt head markings and AF measurement, and not M12. |
17th Mar 2021 9:58am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Where I got my replacements
https://yrmit.co.uk/?s=steering+bolt&post_type=product |
17th Mar 2021 12:08pm |
Try ordering a set then and see what Land Rover provide: https://www.brit-car.co.uk/product.php/145...anged_head https://www.brit-car.co.uk/product.php/145...mm_flanged |
17th Mar 2021 6:08pm |
Click image to enlarge |
17th Mar 2021 6:14pm |
Fair enough, but it doesn't alter the parts list and doesn't alter what is on my vehicle. I suspect that it is another cost-cutting exercise by LR.
17th Mar 2021 6:19pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
https://www.lrworkshop.com/parts/FC112326
https://www.lrworkshop.com/parts/FC112246 LR list these (or have listed these) as 1/2 UNF. Even the matching nut FY112056 is listed as 1/2 UNF on the 2007 on diagram: https://www.lrworkshop.com/diagrams/land-r...s_44790#21 However these are all M12, the part numbers decode like this: FC 1 12 32 6 Fastener type METRIC M12 Length/5 = 160mm Variant/Finish Similar for the Nut - xx112xxx is an M12 nut Td5 and earlier are definitely 1/2 UNF, this is up to 2006: https://www.lrworkshop.com/diagrams/land-r...s_52609#20 Part number e.g. BH608381 decodes as: BH 6 08 38 1 Fastener type UNF x/16ths x/8ths Variant/Finish Bolt Hex? inch = 0.5" inch = 4.75" Another case of LR copying the parts sheet over to the Puma, but in this case only changing half the info (the part numbers and not the description). http://fuddymuckers.co.uk/tools/lrfasteners.html (Yes I've been wrong about this in the past, now corrected) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
17th Mar 2021 6:43pm |
The part number decode is interesting. Curious that my '07 Puma definitely has UNF fasteners!
The only consistent thing is the inconsistency. |
17th Mar 2021 8:01pm |
Thanks for all the replies guys- I’ve ordered a set from YMrit
Marcus Keswick green 2007 Defender 90 TD5 |
18th Mar 2021 9:23am |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 632 |
If this was a social media post I'd be saying 'I was today years old when I discovered this'.
Absolutely brilliant bit of info - I've been looking at parts books for 30 odd years and never ever knew or suspected that there was a coding in the number. JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
18th Mar 2021 11:20am |
I notice also that the metric parts are flange head and the UN parts were not. Again I suspect that this is financially-driven since it eliminates the need to stock (and manage the stockholding of) and fit washers, which in volume manufacture must make a worthwhile difference.
18th Mar 2021 1:10pm |
