Home > Maintenance & Modifications > I have cut something off I shouldn't have....HELP!
Page 2 of 2 <12
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Thanks for all the replies guys- to make the situation even worse whilst replacing the top right panhardrod bolt the cut end has dislodged something on the coolant system (I think) when I was knocking the old cut end through.
This photo is taken from underneath behind the radiator where the end of the top panhardrod bolt comes through.
When I squeeze the large coolant pipe coolant flows out of the part in yellow.
My question is - it looks as though I have knocked off a pipe connection or cap that sits over the part in yellow- what normally would be connected to the front right side (TD5 defender)
Once again thanks in advance!
(This may be the last thing I try to do to my defender at this rate!
) Keswick green 2007 Defender 90 TD5
Post #893115 21st Mar 2021 10:53pm
Teario
1998 Defender 90 300 Tdi SW Rioja Red
Today I was killing time on youtube and saw a video titled "I made a mess of my Defender". I took the bait and gave it a watch, all the while thinking I'm absolutely certain I saw someone on d2.net have this exact problem! Had to come and have a look to make sure I wasn't going mad!
Some decent videos on your channel Marcus. Especially liked watching the couple you've done on soundproofing because I am currently about to do that job on my 110.
Post #894735 29th Mar 2021 5:35pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Had the same thought I had seen somebody cut the same bolts then have to change a pipe/rad. You can not hide now you are famous Marcus Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #894742 29th Mar 2021 5:55pm
MarcusM
Haha thanks guys yes itโ€™s me with the very amateur YouTube channel and mechanical skills!
This radiator issue has been a nightmare but getting there!! ๐Ÿ™๐Ÿผ Keswick green 2007 Defender 90 TD5
Post #895004 30th Mar 2021 8:22pm
Page 2 of 2 <12
