Home > Td5 > headlamp improvement
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
I'm thinking my next improvement will be sorting out the headlamps as they throw a fairly pitiful pattern, whats peoples' suggestions or recommendations please? Cool 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #89171 15th Sep 2011 5:40am
abomb1969
United Kingdom 1998 Defender 110 Td5 CSW Santorini Black
The first time I put mine on I was staggered at the yellow tint, and the lack of power. Someone at Peterboro was selling HID kits for £89, but I have seen some on ebay for £40. I am tempted! My main beam is amazing thanks to the spots on the a bar.
Post #89183 15th Sep 2011 7:08am
Naks
Replace with Wipac clear lenses and use Osram Nightbreakers or Philips Extreme Vision.
Bang for buck you cannot go wrong with this setup Thumbs Up
http://www.paddockspares.com/wipac-crystal...ralia.html --
Post #89185 15th Sep 2011 7:21am
SVX copies on mine....Bolt On Bits...ebaY !
Post #89186 15th Sep 2011 7:28am
Naks
I heard the Bolt On Bits products are not very good? --
Post #89187 15th Sep 2011 7:29am
I fitted the Phiips X-treme Power bulbs to my old Freelander and they were excellent.
My completely un-scientific test Darren
Post #89188 15th Sep 2011 7:31am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Yup crystal bowls are next on my list. Halfords "extreme brilliance" bulbs (or similar) make a HUGE difference. And they're 2-for-1 at Halfords at the mo.
HID kits are illegal unless your vehicle has automatic headlamp levelling and headlight washers, which pretty much rules out all Defenders. You might get away with it if you had a self-levelling equipped 110 and fitted headlamp washers, but I think you'd be skating on pretty thin ice...
Post #89189 15th Sep 2011 7:32am
markb110
As per Greeni and TwoPoint6
Makes a big difference now that the nights are drawing in. Also makes the car look a little more modern. Very Happy
The lights are made by Wipac and sold via Bolt on Bits - Devon 4x4 also do them as i guess other suppliers
Good luck
Mark
Post #89190 15th Sep 2011 7:36am
RED-DOT
I spent £70 on PIAA upgraded bulbs and they threw a whiter light but to be critical they did not throw as far so i am back to standard with HELLA Dynaview spots and it seems OK. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #89201 15th Sep 2011 8:06am
BigMike
extreme brilliance bulbs are excellent. as are osram nightbreakers, though the latter are more expensive for not much difference.
forget light bars, spots, all that crap, theyre not needed.
Post #89205 15th Sep 2011 8:25am
Surrey Rover
I put a HID kit on my last 90 and although it's a massive improvement I did have problems with other drivers.
My headlights were set correctly but I did find they were so bright that with a slight load in the rear (or towing) it caused constant flashing from other drivers.
Although at the time the HID kit cost me about £200 I left it in the last 90 as I didn't want the hassle in the new one.
10/10 for brightness but a pain in the bum unless you have self levelling.
Post #89208 15th Sep 2011 8:50am
chiefstoker
HID kit is out for me, too much hassle come MOT time. Crystal lenses and Halfords bulbs then if they are on offer Thumbs Up I have fitted the Phillips bulbs before and they are considerably brigher for the same wattage Cool 2005 TD5 90 Hard Top
Post #89299 15th Sep 2011 7:27pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
I fitted mine with Wipac clear lenses and Osram Nightbreakers on Sunday then drove in the dark from Chester to Broadhaven in Pembrokeshire what an improvement..... I could see and so it was a much more relaxing drive, except for the wind and rain. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #89362 16th Sep 2011 12:27am
chiefstoker
Are they all H4 bulbs? 2005 TD5 90 Hard Top
Post #89366 16th Sep 2011 6:03am
they are all H4.
PIAA are based in W-S-M ... they produce fantastic H4 bulbs
Post #89368 16th Sep 2011 6:25am
