![]() | Home > Technical > How to diagnose injector seals leaking on 2.2 tdci? |
I'd expect you to be able to smell diesel in the oil. Darren
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
Thanks gents.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
I'm not sure that you would with a TDCi, this tends to be a TD5 symptom. The TD5 has the fuel rail incorporated into the head as a gallery within the casting, and the injectors therefore have two seals, the copper washer to seal the cylinder/injector interface and an "O"-ring to seal the gallery and prevent leakage from the gallery past the injector into the rocker space. Lubricant dilution with fuel on a TD5 is most commonly caused by the "O"-ring leaking. The TDCi has an external fuel rail and hence should be more or less immune from the lubricant dilution mechanism above. Leaking seals on the TDCi will cause cylinder gasses to blow past the injectors and will generally result in smoky vapours from the breather system, oil being blown into the induction passages, and oil leaks from the top cover. It won't result in fule in the lubricant however. Lubricant dilution with fuel on the TDCi is generally the result of a dribbling injector overfuelling a cylinder (or more than one injector overfuelling more than one cylinder) so that incomplete combustion takes place, a damaged piston or bore resulting in no combustion taking place, leaving fuel in the cylinder, or, for the 2.2 version only, a problem wit the DPF regeneration cycle. The first two of these (but not the DPF issue, of course) can also happen to a TD5. |
I couldn’t smell diesel, but as Blackwood explained this may not be a symptom. What I found was that the area around the 4th injector looked “wetter” than the rest. I also took the oil filler cap off and it was definitely puffing a bit. I held my hand over the hole for a second and got a fair bit on the glove. Is this the norm though?
![]() Click image to enlarge ![]() Click image to enlarge |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
![]() I had an oil leak and it turned out to be these LR018370. The main dealer automatically assumed it was the injector seals and changed them but that was not the case. Same number for the 2.2 and the 2.4. ![]() Click image to enlarge https://www.lrdirect.com/LR018370-Seal/?keep_https=yes Here is a choice of makes. ![]() Click image to enlarge £3.53 from Advanced Factors 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
In this case, a compression test may help |
Thanks Julie. Off to a specialist on Friday for a second opinion. My soon to be ex-garage just uttered the fateful words; it’s a defender, they all leak!
BIMbound Member Since: 09 Jan 2021 Location: UK Posts: 44 ![]() |
2.4 TDCi. I didn't know my injector seals were leaking but there was an unpleasant oily/fume smell coming through the vents, now replaced this has been cured.
