Home > Puma (Tdci) > Inexpensive puma gear knob solution?
Page 2 of 5 <12345>
BADCADI
Switzerland 2010 Defender 110 Puma 2.4 CSW Alaska White
Hello Samblers - thank you for your response and information.
This is an intriguing solution, and as it happens, PC-7 is available in the UK. I may just have to give that a try. Thumbs Up
BADCADI
Post #891274 14th Mar 2021 8:15am
Samblers
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
You're welcome. I pick my battles over where the money gets spent on this car!
Sam
Post #891341 14th Mar 2021 1:32pm
Ecco
Malaysia 2014 Defender 110 Puma 2.2 DCPU Galway Green
blackwolf wrote:
..actually, i found this one quite attractive..is this some sort of kit or you made it yourself?? If so, do you mind to share details/links/anything? Mine is long gone, so i teared soft rubber thing from outside and its some sort of hard black plastic underneath and it looks like tightened with one bolt in center..so it should be simple to replace it i guess?
Post #897401 11th Apr 2021 11:54am
The bevel you can just see in the photo where the steel shaft emerges from the rubbery coating is the remains of the groove around the base of the original knob. With a hacksaw I very carefully cut through the rubbery coating down to the steel core all around the shaft, then broke up and removed the remains of the old knob. I then cut an M12 thread on the end of the steel inner shaft and fitted a standard M12 threaded knob (eBay or Amazon, I'll see if I can find a link) with an M12 half nut to lock it.
Tools needed: hacksaw, files (to clean up the cut surface), M12 die and diestock. Materials: knob, M12 half nut. Cost: around a fiver and half-an-hour of effort.
It's more comfortable than the original knob to drive with and whilst it won't appeal to the blingy sector I think it has a nice heritage flavour.
Post #897417 11th Apr 2021 12:39pm
Bluest
How far down goes the metal core go? Would be possible to remove all the plastic down to the gator and just in effect have normal Land Rover style metal gear stick? 2007 110 TDCi Station Wagon XS
Post #897460 11th Apr 2021 3:52pm
I don't know, and it is hard to tell. The gubbins under the gaiter is quite elaborate and whilst I would have preferred to go fully retro and cut it down to the gaiter I wasn't brave enough to risk it. Does anyone have access to an x-ray machine, or have a totally scrap lever they could cut up? Even second-hand they are a bit pricey just to destroy.
I see to remember that the nylon spike on the pivot actually extends above the gaiter inside the upper lever.
There is a lot of weight in the bottom of the lever (to provide damping, no doubt) and it feels as though there is more than just the steel shaft in there.
This is the knob I used:
Post #897502 11th Apr 2021 4:50pm
Ecco
Here is my current 'situation'. Basically, rubbery thing is gone, so what is left is this very hard, shiny plastic thing, with bolt in center. Im wondering, is this bolt holding only plastic knob on the top or there is more to it, in case one want to have shiny stainless steel stick???
Post #897719 12th Apr 2021 2:20pm
I think the "bolt" is the top of the steel armature. Why do you think it is a bolt, as opposed to a plain steel shaft?
You will find that there are two (I think) holes cross-drilled through the shaft which I imagine are there to allow the polymer to bind more tightly to the shaft. Mine looked very like yours before I operated, and I do think that the £4 knob looks better that than the necrotic Landrover monstrosity!
Post #897729 12th Apr 2021 3:06pm
Jeepy
France 2008 Defender 110 Puma 2.4 SW Keswick Green
My personal solution, just cut the plastic with a saw gently up to the rod and extract the knob as you can, there is 12 mm metal insert in the center ,now you can fit an aftermarket knob or diy your with a late,i do like this since one year and work like a charm Thumbs Up
Post #898045 13th Apr 2021 5:55pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
I'm surprised that someone hasn't made a reasonably priced metal gear stick that takes generic knobs. The leather and alloy sticks available are over £360 so are an expensive upgrade certainly not for everyone.
i'd like my knob (ooh er missus) to be leather rather than plastic but I don't want to cut my stick up (and risk f'ing it up). You have cool products out there like Slick Shift and TMD's Shift-R. Either are money well spent but you still have your old plastic stick. I think an affordable stick/knob solution would be a nice seller as opposed to the expensive options that currently exist.
Post #898128 14th Apr 2021 8:34am
Ijk10
Wales 2007 Defender 110 Puma 2.4 CSW Keswick Green
ashtrans wrote:
Hi,
I have loads of these brand new from auto conversions, �25 each + carriage
I am now off for a week but if you want one email me a week on Monday
Dave
Hi Dave
Could I have one please. Email me on Ijk72@hotmail.com
Post #899075 19th Apr 2021 8:42pm
Ianh
Ashtrans did post that in August 2016, he may well still have some. But I think it may be a long shot given it was nearly 5 years ago
Post #899086 19th Apr 2021 11:57pm
geostrategist
United Kingdom 2008 Defender 110 Puma 2.4 CSW Tonga Green
I’m in the same situation as Ecco above.
My temporary fix is actually quite comfortable to use!
Post #965550 20th Sep 2022 4:25pm
ChrisCSL
Laughing
perfect
Post #965714 22nd Sep 2022 2:11pm
Ecco wrote:
Looks like a pool 8 ball..... (I've got plenty at work if anyone wants.... or a red or yellow ball, give it a nod to the series 4wd/Hi-low range levers Whistle )
Post #965741 22nd Sep 2022 5:52pm
Page 2 of 5 <12345>
