Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 |
An awful lot of technology has happened in the past 34 years, the alternative then was either/or.
9th Mar 2021 4:15pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
I agree with the above, there is no denying it but they seem to be making things really complicated. I know they are not alone in this but wouldn't it be great if all of these glitches were detected pre sale? 1982 88" 2.25 diesel
9th Mar 2021 4:20pm |
Nobody would mind the odd problem if there was an efficient system in place to deal with it. Here's hoping everything clicks into place for you. 1982 88" 2.25 diesel
9th Mar 2021 10:38pm |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
Yes I wasn’t expecting it to be trouble free especially being a first edition model but the dealership service department don’t seem to be competent in what they are doing! Basic checks to the engine bay were missed (low engine coolant) and no rolling test drive was done to identify the mechanical noise on braking. No referring to Land Rover Assist diagnostic report to see what they had identified as the problem etc just seems bizarre that any Land Rover engineer would not do these basic checks.
9th Mar 2021 11:02pm |
@Supacat just had the service mechanic on the phone, they wanted me to run through all the problems so I went through them all and they focused on the mechanical noise which they mentioned the brake disk recall that you posted last week, I told them it’s a mechanical noise and I highly doubt that it is anything to do with the disk. They said the 2WD should be sorted now after software update which I’m doubtful was the problem. They then said the differentials locking is the torque vectoring working which I disagreed and mentioned that nobody else’s vehicle in the forum is doing it and that they were locked most of the time. The engine coolant they are going to do a compression test for leaks. I’m really annoyed they are trying to push the mechanical noise as a brake disk recall problem, I said listen to my YouTube video and tell me that is a brake disk!
I really don’t have much faith in the mechanics sorting these problems out. |
10th Mar 2021 10:21am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Be careful that the dealers aren’t dragging this out to passed the 30 day rejection period for a new car
https://www.thecarexpert.co.uk/rejecting-a-car/ Scroll down to the “short term” bit Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
10th Mar 2021 10:58am |
It has past that period now Tim.
10th Mar 2021 11:03am |
Those problems were supposed to be limited to the 19" wheels and the nature of the issue with the disc surface meant the juddering/noise was only apparent under braking. Three things there - Ask them for details of the software update - was it this one? If the software was not SSM 75294, then ask for a copy of that also and see if you thing it is applicable to your issues. Ask them about SSM 75152 for Range Rover & Discovery - if yours has been suffering from "excess duty" on the clutches in the differential and transfer case (as evidenced by your video), then shouldn't they be undertaking similar remedial work. Noting, if flushing them both does not solve the problem, the JLR solution is (in the case of the transfer case) replacement of the transfer case. From your video, it's hard to see why torque vectoring would be required whilst moving in a straight line, at low speed on a high grip metalled road; but then who know's what goes on in the head of a JLR's software engineer? Have they checked the oil dipstick? Maybe get the CR chap involved? https://www.defender2.net/forum/land-rover...-vf41.html |
10th Mar 2021 11:45am |
Thank you very much Supacat your knowledge on defenders/Land Rovers is second to none I appreciate your help.
I have checked my remote app and at least they are doing rolling test drive in my car now Waiting for them to come back to me with progress on the repairs but I will be sure to check what they have done and update the forum when I know more. Last edited by Digger2000 on 10th Mar 2021 5:37pm. Edited 1 time in total |
10th Mar 2021 4:30pm |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
You may want to edit that last photo if one of those is your home address...
10th Mar 2021 4:49pm |
SN Member Since: 29 Jun 2007 Location: SK6 Posts: 729 |
yep - at least blur them - I know which of those is JLR, we have an office round the corner! Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
10th Mar 2021 4:56pm |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
Agreed! |
10th Mar 2021 5:07pm |
Cheers for the heads up, it wasn’t actually my home address....another glitch in the app
10th Mar 2021 5:38pm |
See, the car’s looking after you whether you know it of not!
It’s got to go! |
10th Mar 2021 5:44pm |
