Home > Technical > Brake pipe material and diameter? |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
I need to build a complete brake pipe system for my '89 110, and I am a little confused by the all the options, I wonder if anyone could clarify things for me please?
The vehicle is not very 'standard' anymore, having had a rear disc conversion on the Salisbury axle, and fitted with the more up-to-date vented front discs and calipers. I have looked at the complete system from Pioneer 4x4: https://pioneer4x4.com/collections/complet...-1983-1990 but I already have the extended flexible brake fittings from Gwyn Lewis, and being a disc conversion I suspect that kit wouldn't fit. Plus - I think I would prefer hard lines rather than flexible ones, I might just be old fashioned but it seems to me having them rigidly fixed to the top the chassis rail is a nice and reliable setup. Similarly the pre-built kit from: https://automec.co.uk/products/brake-pipe-...-wagon-rhd is unlikely to fit due to the disc conversion My Father has lent me a good quality brake pipe flaring tool and pipe bender, so the next option is construct it all myself, and I see that I can get 'coils' of 3/16" copper-nickel from Automec, which I understand is the size used on Land Rovers? https://automec.co.uk/collections/brake-pi...l-imperial What about the fittings? Automec sell fitting kits in metric and imperial at: https://automec.co.uk/collections/fittings...ssortments RallySteve stated (https://www.defender2.net/forum/topic77086.html) that the fittings are metric for the Defender - but if that is the case I am confused why Wrights Auto Supplies selling a kit which uses UNF fittings? https://www.wrightsautosupplies.co.uk/prod...-in-brass/ Most of these retailers off both pure Copper, and a Copper/Nickel mix (Kunifer I think its called?). I gather the copper option is a little more flexible and so easier to bend, but then what is the benefit of the Copper/Nickel mix - a bit more corrosion resistance and less work hardening? Cheers! Chris. 2005 Td5 90 XS 1989 V8 110 CSW Last edited by Hufflepuff on 8th Mar 2021 1:12am. Edited 1 time in total |
7th Mar 2021 10:05pm |
Thanks for the reply I Like Old Skool.
That matches what RallySteve was saying, so that is good. I'm very confused by that kit from Wrights though, I wonder why they are listing it as having UNF fittings...? 2005 Td5 90 XS 1989 V8 110 CSW |
7th Mar 2021 10:47pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2683 |
Kunifer is what you want, 3/16” diameter. All fittings are M10x1 as noted.
If you’ve got the standard rear disc setup and vented fronts then you’ve basically got the standard setup for a 1993 - 2005 (ish) 110. |
7th Mar 2021 10:49pm |
Right that is clear then. Thank you gentlemen, I shall get that ordered. 2005 Td5 90 XS
1989 V8 110 CSW |
8th Mar 2021 1:13am |
chip butty Member Since: 12 Mar 2018 Location: manchester Posts: 8 |
Hi just a quick one.If you make your own pipes, check that the flaring tool will make metric ends.Imperial pipe for both, metric male fittings metric flare.Imperial male fittings imperial flare.
8th Mar 2021 11:51am |
