Home > Td5 > Rear door 2004 90 power problems |
Click image to enlarge Rear wiper motor 1. check earth wiring between door and door pillar common frailer in rubber flex ( black arrow ) 2. fuse 10 passenger compartment fuse box feeds the rear wiper cct also make shore you 12v volts to the fuse feed from ignition switch white wire 3. check engine end chasse loom plug down under coolant header tank Central locking motor to work. 1. Are all the other central locking motor ? 2. check for power when opiating central locking at plug ( red arrow ) pink and orange wiring runs up D post and over too driver side under head lining at A past driver side gray plug 3. if you have power when opiating central locking at plug ( red arrow ) again check wiring in between door and door pillar common frailer in rubber flex ( black arrow ) Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 16th Jan 2021 10:17pm. Edited 6 times in total |
16th Jan 2021 8:06pm |
russd86 Member Since: 21 Jan 2018 Location: Lancashire Posts: 20 |
Checked the fuses, all seem ok.
Didn’t know about the plug under the header tank. I’ll try that next!! Cheers!! Russ |
16th Jan 2021 8:15pm |
Quick update.
So... this may be the main culprit. Still no power to the rear wiper. But with the help of the wiring diagrams I’m tracing it down slowly!! |
13th Feb 2021 11:30am |
Pic attached
13th Feb 2021 11:32am |
Beero Member Since: 05 Jan 2021 Location: Southampton Posts: 21 |
As Dorsetsmith says in point number 1, check the loom inside the rubber flexi tube between the door and the body. I had one wire broken and a few others where the insulation had cracked on my 2005 TD5 Defender. It is repairable if you have a soldering iron and some shrinkwrap tubes. |
13th Feb 2021 4:15pm |
Hey guys.
Just a quick update. So we found 5 broken wires, 1 seized wiper motor, 1 knackered switch, bad connections in a plug, and a partridge in a pear tree!! Thank you to you all for your help and input!! Rear door power is back on and everything is working again! Thanks again!! Russ Click image to enlarge |
15th Feb 2021 9:10pm |
