Home > Td5 > Rear door 2004 90 power problems
russd86
United Kingdom 1993 Defender 90 300 Tdi ST Firenze Red
Hi.
I’ve just bought a CSW 54 plate 90.
Trying to get the rear wiper motor and central locking motor to work.
Replaced both but no joy.
I have no power to either motor plugs, even traced back to the rear wiper switch
Nothing. I do have power to the 6 way plug. But the switch has nothing to that plug. Sa
Does anyone know if I possibly have a dead relay or any idea where I should start?
Post #878908 16th Jan 2021 5:20pm
dorsetsmith
Rear wiper motor
1. check earth wiring between door and door pillar common frailer in rubber flex ( black arrow )
2. fuse 10 passenger compartment fuse box feeds the rear wiper cct also make shore you 12v volts to the fuse feed from ignition switch white wire
3. check engine end chasse loom plug down under coolant header tank
Central locking motor to work.
1. Are all the other central locking motor ?
2. check for power when opiating central locking at plug ( red arrow ) pink and orange wiring runs up D post and over too driver side under head lining at A past driver side gray plug
3. if you have power when opiating central locking at plug ( red arrow ) again check wiring in between door and door pillar common frailer in rubber flex ( black arrow )
Post #878956 16th Jan 2021 8:06pm
russd86
Checked the fuses, all seem ok.
Didn’t know about the plug under the header tank. I’ll try that next!! Cheers!!
Russ
Post #878962 16th Jan 2021 8:15pm
russd86
Quick update.
So... this may be the main culprit.
Still no power to the rear wiper. But with the help of the wiring diagrams I’m tracing it down slowly!!
Post #885225 13th Feb 2021 11:30am
russd86
Pic attached
Post #885227 13th Feb 2021 11:32am
Beero
As Dorsetsmith says in point number 1, check the loom inside the rubber flexi tube between the door and the body. I had one wire broken and a few others where the insulation had cracked on my 2005 TD5 Defender. It is repairable if you have a soldering iron and some shrinkwrap tubes.
Post #885301 13th Feb 2021 4:15pm
russd86
Hey guys.
Just a quick update.
So we found 5 broken wires, 1 seized wiper motor, 1 knackered switch, bad connections in a plug, and a partridge in a pear tree!!
Thank you to you all for your help and input!!
Rear door power is back on and everything is working again!
Thanks again!!
Russ
Post #885774 15th Feb 2021 9:10pm
