![]() | Home > Maintenance & Modifications > Optimill QR steering boss - advice please! |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
they do sell separate parts if you message them and ask
![]() 2008 SVX 90 2000 XS TD5 90 |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Thanks Suki I will do that.š
Hi x4 did you block up the holes on your snap of boss? |
Gerry Member Since: 22 Oct 2017 Location: north Ireland Posts: 35 ![]() ![]() |
Is it suitable for road use or is having one on a road car an automatic MOT failure?
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 518 ![]() ![]() |
I had one on mine and it was never an issue
![]() ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
northernerindevon Member Since: 27 Feb 2018 Location: Bristol Posts: 62 ![]() ![]() ![]() |
I'm afraid this wasn't the case for me. I contacted Kath at Optimill with a view to trying to purchase an additional boss (ie the bit that the steering wheel attaches to) as I have 2 steering wheels which I'd like to swap at will but they are unable to supply just the boss. I can see why but its still a shame. Despite this the quality is excellent, the customer service is excellent and the whole kit with the swivel lock is fantastic. I'll echo the thoughts about the pins being silver but I have sprayed mine black, following on from Darrens thread (LandRoverAnorak) & this has finished the kit off a treat https://www.defender2.net/forum/post786128.html#786128 Cheers, Paul |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
Same here - I can't remember when I first fitted mine, but it's been through at least 2 or 3 MOTs without any comment at all. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 282 ![]() ![]() |
I've had the Optimal QR for 7/8 years and noticed that the two silver locking pins attached to the back of the steering wheel have developed a very slight amount of play. Annoyingly the slack can now felt when turning the steering wheel in either direction. Is there any way to tighten the pins or do I need to cough up for a new removable boss?
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2138 ![]() ![]() |
Give Optimill a call, advise of the issue and Iām sure they will resolve it with you.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 628 ![]() ![]() |
I have the optimil quick release wheel and while it's not in front of me now I think those two side pins locate on a taper.. if the fully extended position of those pins could be eased slightly to allow a bit more inward movement , that should remove play and might solve the issue..
I'm assuming that the central locating boss hole is still a very close fit.. |
