Home > Maintenance & Modifications > Optimill QR steering boss - advice please!
Page 6 of 6 <123456
Sulisuli
they do sell separate parts if you message them and ask Whistle 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #884881 12th Feb 2021 8:21am
nitram17
Thanks Suki I will do that.šŸ‘
Post #884887 12th Feb 2021 8:51am
Sulisuli
I rang them when I need one, it wasnt cheap I have to say but the quality is good but ring them direct. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #884982 12th Feb 2021 2:38pm
nitram17
X4SKP wrote:
Anyone roaming around the various threads generally reading up
about a Quick Release Steering Wheel Boss and wondering if it's
either worth the money / the effort to change / the security benefit...
or all of the above, please read on.
I would recommend that you get your hands on a good example and then
just find a reason that makes sense to you to fit this to your Defender.
I have a good friend who has the Optimill offering + lockable 'cap'
all doing its best to secure a Twisted 110 that you really wouldn't
want to loose... it's an excellent bit of kit and I would not hesitate
to fit one if starting again.
I have the Snap-Off Boss which was fitted during my first week of ownership,
so coming up to 5 years now, 40K miles later, No play what so ever, probably
2-3 seconds to remove the steering wheel and store or to reengaged...
FANTASTIC... Thumbs Up
For me, one of many layers overall, but it's right up there in my top 3 of would
not be without security layers / products, and definitely my top visual + mechanical layer.
I genuinely don't understand why I don't see more Quick Release Steering Wheels
fitted to Defenders... Shocked
(I know that sounds a little 'preachy' so please don't give me a hard time Wink )
Good Luck...
Hi x4 did you block up the holes on your snap of boss?
Post #886417 18th Feb 2021 11:00pm
Gerry
Is it suitable for road use or is having one on a road car an automatic MOT failure?
Post #895410 1st Apr 2021 5:13pm
Smyles_
Denmark
I had one on mine and it was never an issue Thumbs Up Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #895418 1st Apr 2021 6:02pm
northernerindevon
United Kingdom 1986 Defender 90 300 Tdi HT Nato Green
I'm afraid this wasn't the case for me. I contacted Kath at Optimill with a view to trying to purchase an additional boss (ie the bit that the steering wheel attaches to) as I have 2 steering wheels which I'd like to swap at will but they are unable to supply just the boss.
I can see why but its still a shame.
Despite this the quality is excellent, the customer service is excellent and the whole kit with the swivel lock is fantastic. I'll echo the thoughts about the pins being silver but I have sprayed mine black, following on from Darrens thread (LandRoverAnorak) & this has finished the kit off a treat
https://www.defender2.net/forum/post786128.html#786128
Cheers, Paul
Post #895480 2nd Apr 2021 5:35am
donmacn
Same here - I can't remember when I first fitted mine, but it's been through at least 2 or 3 MOTs without any comment at all. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #895540 2nd Apr 2021 11:02am
stephan123
I've had the Optimal QR for 7/8 years and noticed that the two silver locking pins attached to the back of the steering wheel have developed a very slight amount of play. Annoyingly the slack can now felt when turning the steering wheel in either direction. Is there any way to tighten the pins or do I need to cough up for a new removable boss?
Post #1049898 26th Oct 2024 9:57pm
Ianh
Give Optimill a call, advise of the issue and Iā€™m sure they will resolve it with you.
Post #1049902 26th Oct 2024 11:27pm
andy63
I have the optimil quick release wheel and while it's not in front of me now I think those two side pins locate on a taper.. if the fully extended position of those pins could be eased slightly to allow a bit more inward movement , that should remove play and might solve the issue..
I'm assuming that the central locating boss hole is still a very close fit..
Post #1049912 27th Oct 2024 8:52am
Page 6 of 6 <123456
