Home > Wheels & Tyres > Wheel spacers for Penman |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 388 |
Keith,
Thanks for the PM I did reply Update... what is the diameter of the center section of the spacer ? (i havent got mine to check right now) I have queried this on the FB penman page and one person uses the Bulldog spacer which are supplied either as 99mm or 115 mm diameter. Brian 2015 90 XS Santorini Black |
10th Feb 2021 3:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 |
It would be a relatively simple job to machine the spacers to fit the hub.
10th Feb 2021 3:23pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 |
The spacers have an ID of 113mm and the flange has an OD of 115mm
Looks like I'm off to find a local engineering firm to machine down the internal diameter of the spacer Keith |
10th Feb 2021 3:32pm |
<"Pedant_mode_on">
Er, machine UP the internal diameter of the spacer (or machine down the hub)! <"Pedant_mode_off"> |
10th Feb 2021 4:17pm |
Good point Keith
10th Feb 2021 4:20pm |
