Home > 130 > Shock absorbers
Rodo68
Chile 2009 Defender 130 Puma 2.4 HCPU Stornoway Grey
Shock absorbers
Hello friends
When I assembled my Defender 130 I put some britpar shock absorbers I think they were the most economical, I don't know if they will be good or bad, but when I drive I feel as if they will blow, the thing is that I want to replace them with softer and better quality ones, my Driving is 80 on the road and 20 on the ground, which you recommend, I forgot to tell you that I suffer from the spine.
Greetings to all[/b]
Post #879238 18th Jan 2021 1:47am
jst
Old man emu Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #879257 18th Jan 2021 8:32am
You could do a lot worse than standard Land Rover ones. Britpart substitutes are rubbish in my experience. If you want softer suspension though, you'll also need to look at springs as the standard on a 130 will be heavy duty. Darren
Post #879258 18th Jan 2021 8:33am
camelman
I'm running standard springs (with rear helpers) and shocks on mine. Does the trick.
Post #879269 18th Jan 2021 9:28am
130dreamer
As others have said, standard Land Rover ones work well.
If you find the ride too harsh and you don't carry heavy loads you could remove the inner helper springs.
My 130 is a station wagon and I have kept the helper springs and don't find the ride harsh.
Post #879294 18th Jan 2021 11:28am
johnnyha
1996 Defender 90 300 Tdi CSW Epsom Green
jst wrote:
Old man emu
snap
Post #933536 14th Dec 2021 12:05pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
OME if you want a good ride. Thumbs Up Rolling with laughter
Post #933560 14th Dec 2021 2:29pm
