Home > My Defender > Fuji 110 LS3 build |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2927 |
This one is way better. We have overhauled pretty much everything and haven’t cut corners. I called up this evening to drop off some parts and heard it for the first time. So much nicer to the last, deeper tone so very happy indeed. Just decided the tip position which is pretty much standard, got the new header tank in and new pioneer brake lines on so should be back on the ground by the weekend which is a big step forward. Don’t even think I am going to badge this one up with LS3 etc. Go under the radar.
Click image to enlarge Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
12th Jan 2021 11:27pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
I'd keep it badge less if it were mine, real sleeper. James
13th Jan 2021 6:23am |
Just ordered a new genuine Silver rear badge as I think it’s better on the Fuji.
13th Jan 2021 6:36am |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
Looking mental Andy.
LR badge is a nice touch, did you decide on how you're going on the front end - TD5 style Defender etc? Sleeper sounds much more fun for the traffic light Grand Prix! A 110 Tdci Double Cab |
13th Jan 2021 9:55am |
I with just keep the twisted front for now. Andy
13th Jan 2021 12:48pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 |
Loving that awesome burble sound there Andy and it's great that you've gone down the sleeper look with not putting on the badges and having the single exit exhaust Clayton.
13th Jan 2021 8:18pm |
Coming along nicely now. Badly needs a nice cover for the LR ECU.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
15th Jan 2021 7:02am |
That’s all the coolers fitted. Comes up to temperature nicely and just idles away with no concerns. Plan to get it onto the wheels again tomo, moved over to the other side of the workshop and wings back on. Then we can get better access to start on the inside.
15th Jan 2021 8:29pm |
Great work there Andy as you say, coming on nicely
I hope it's just me, but keep an eye out on the header tank level window as after some months went by i was losing water and it turned out to be the bit of plastic they use was cracked / split. I did get a couple of replacements, but they also cracked / split, so that is why i don't have my header tank on any more Click image to enlarge Click image to enlarge Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
15th Jan 2021 8:49pm |
Thanks for the heads up, will definitely keep an eye on it. I actually didn’t really want the window but it was the only one I could get in a hurry. Andy
15th Jan 2021 8:54pm |
That seems the way at the moment with not much items in stock Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
15th Jan 2021 8:59pm |
Exhaust has come out a treat
15th Jan 2021 9:12pm |
That radiator is a monster! Will it eliminate the need for sawing holes in the bonnet? James
16th Jan 2021 6:28am |
It’s the go to setup for the guys that do the conversion in hotter countries but I just thought I would be prepared for when Ireland has its next heat wave Andy
16th Jan 2021 6:33am |
