Home > Wheels & Tyres > Steel Wheels to Fit TD5
2004_TD5_NZ
New Zealand 2004 Defender 110 Td5 SW Santorini Black
Hi, i'm sure this question has been asked a number of times and I have done my best to try and find the answer before posting a new topic. I am trying to find the code for the correct steel wheels to put on my TD5. I was about to purchase an old set to restore stamped with the code 231601. From what I can make out these were for Series 3 LR. I guess my question is whether these will be OK on a TD5 or if I need something different?? Cheers !
[/img]
Post #872683 13th Dec 2020 9:36am
ibexman
All the standard Land Rover wheel will fit some you may have to fit longer studs đź‘Ť
Post #872685 13th Dec 2020 10:31am
dorsetsmith
The only other thing tube or tubeless Exclamation
Post #872688 13th Dec 2020 10:53am
Retroanaconda
The series III wheels would fit but they would be tubed.
Your best option would be either standard tubeless steel wheels from a later model 90/110, or the Wolf/HD rims (also available tubeless) for a much stronger wheel. The latter is also 6.5” wide rather than 5.5” which allows you to run a bigger selection of tyres.
Post #872691 13th Dec 2020 11:11am
2004_TD5_NZ
Thanks - yeah I was confident that they would fit but wasn't sure if it would be unsafe to run a Series 3 wheel on the TD5. I know there some heavier duty options but they are all 6.5 wide. Pretty sure I'm after the ANR 4636 5.5j x 16.
I can see from the photos these ones have tubeless tires on them.
Post #872692 13th Dec 2020 11:11am
Dinnu
Or the tubeless one, RRC503600PM or LR053845. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #872717 13th Dec 2020 1:16pm
gcc130
Just because they have tubeless tires fitted doesn’t mean the rims are suitable, they may be tubed. You should be able to see a ridge in the rim of a tubless rim.
As far as I know no series 111’s had tubeless rims, they came in sometime during Defender production.
Post #872721 13th Dec 2020 1:43pm
2004_TD5_NZ
Yup, you're right, none of the earlier steel wheels were tubeless. These ones I'm looking at must be running tube inside the tubeless tire. They are also riveted - not welded.
Ok so now I'm getting somewhere. I need the RRC503600PM. The LR023152 says it's suited for Defenders 2007 on.
Cheers!
Post #872771 13th Dec 2020 6:54pm
Dinnu
More part number:
To 2006:
https://www.lrworkshop.com/diagrams/land-r...oad-wheels
From 2007:
https://www.lrworkshop.com/diagrams/land-r...eels_44778 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #872778 13th Dec 2020 8:13pm
2004_TD5_NZ
Does anyone know if there is any reason why the LR023152 for 2007+ Defender wouldn't fit on a 2004? Britpart have told me the steel wheel for my VIN is now obsolete and that the LR023152 is not stated as compatible. I could do the ANR4636 but they are tubed. I think I'd prefer to go tubeless if I can.
Post #872977 15th Dec 2020 7:48am
Because Britpart are idiots. There's no difference between the standard tubeless steel wheels used pre and post 2007. I can only guess that the change in part number reflects something like a manufacturer change. Darren
Post #872982 15th Dec 2020 8:46am
Dinnu
Steels rims from the earliest 90/110 era to the latest Defender are physically interchangeable, including classic Range Rover and Discovery 1. There might be load rating difference though, but never checked the details. I assume later ones shout meet tougher requirements.
Alloys are not a straight fit on the earlier 10 spline axles.
I ran my 90 on old Series riveted rims (tubed) for many years and are still in one piece. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #872983 15th Dec 2020 8:56am
2004_TD5_NZ
Damn that was my fist experience dealing with them - painful ! OK cool, thanks very much.
Post #872987 15th Dec 2020 8:59am
teek
I just bought some Kahn 1947 steel wheels for my 1999 100 TD5 (they are on route) to replace the Boost alloys that I've increasingly started to hate. I bought the Kahn's over the Wolf's to get the width (16 x 9") to give more tire choice.
Wheels, Tires, steel nuts, hub caps are all ordered and en-route now.
Question: while the wheels will come with a matte/satin finish and should be ready to go - any advice on protecting them from rust? They use a tonne of salt on the roads here (Ontario, Canada). Thoughts?
Post #876326 4th Jan 2021 10:33pm
crashmtb
Canada 2002 Defender 110 Td5 HT Coniston Green
Re: Steel Wheels to Fit TD5
[/img]
ANR4583PM are the “wolf” HD wheels. They come in black e-coat primer. I powder coated mine white, over the e-coat(an excellent substrate for powdercoating).
LR053845 are the tubeless version of the 5.5” wide wheels your truck probably has. E-coated too.
NB if you’re wanting oem parts, I’ve found JLR Classic to be shockingly reasonable. In Canada at least(can’t speak to NZ of course) cheaper and faster than the dealer. Good fast shipping too.
Post #881873 30th Jan 2021 4:42am
