Home > Puma (Tdci) > Cold start |
Click image to enlarge not a relay (ecu ) glow plug Click image to enlarge Last edited by dorsetsmith on 30th Dec 2020 2:52pm. Edited 1 time in total |
30th Dec 2020 2:41pm |
Howard Member Since: 06 Nov 2012 Location: Oxfordshire Posts: 41 |
Thank you, where will I find the glow plug ECU.
30th Dec 2020 2:44pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Just put a meter on the feed to the glow plugs, engine side, turn on ignition and see if you got power there. At least you've checked it all the way to the glow plugs this way. Manifold is easy to remove, ideally you should fit new gaskets (8 of) Done mine at the start of the month and there was only one working. Started quite well for that though. Just be careful removing the glow plugs. They have a habit of snapping. Spray releasing spray on them for a few days. Try and get them out when the engine is warm.
30th Dec 2020 3:24pm |
Thanks guys for the information. "dorsetsmith" the wiring diagrams are very useful, but unfortunately I can't read the text even when I've printed them off. But I get a general idea. Is the "junction box battery" the fuse board under the drivers seat, it appears the the ECU for the glow plug is powered via a relay and fuse housed in the box? If this is the case which are they
I haven't had time to check the supply to the plugs on the engine side. It appears different to the wiring on our 2.4 Puma. I noticed today the glow plug light on the dash is no long working. Ta Howard |
31st Dec 2020 7:28pm |
link to wiring diagrams left hand drive one but just as good
https://1drv.ms/b/s!AtZSoWFHDgnGlB8iSFfsA9JN_EFj?e=wqacfo |
31st Dec 2020 8:12pm |
Thank you for the link, most appreciated.
6th Jan 2021 9:07pm |
