![]() | Home > Technical > Air intake enthusiasts I need you |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Yeah I did the airbox mod too and removed the hyclone thing with my dremel
Eppilihp Member Since: 10 Aug 2019 Location: Emmental Posts: 61 ![]() ![]() |
Do you mean something like a cone air filter for a Honda S2000? Is anyone running something like that in a Defender? |
Was never fully happy with the look of the ducting so just got round to fitting some proper silicone hoses and another stainless 90 elbow.
Looks a bit more factory now, there’s more clearance below the steering arm and it’s stronger and more rigid. ![]() Click image to enlarge ![]() Click image to enlarge |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Not a TD5 but you get the idea. 102mm pipe from airbox to wing tops. DIY adaptor plate covered with a snow cowl. Can’t get much free-er flowing. Been like this for a couple years. Never had a wet air filter. The inlet is raised from the adaptor plate by about 5mm to reduce the risk of water ingress.
![]() Click image to enlarge ![]() Click image to enlarge Also gives me good symmetry having a snow cowl either side. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Lovely symmetry
