Home > Technical > Air intake enthusiasts I need you |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Yeah I did the airbox mod too and removed the hyclone thing with my dremel
29th Nov 2020 9:51pm |
Eppilihp Member Since: 10 Aug 2019 Location: Emmental Posts: 61 |
Do you mean something like a cone air filter for a Honda S2000? Is anyone running something like that in a Defender? |
23rd Dec 2020 8:29am |
Was never fully happy with the look of the ducting so just got round to fitting some proper silicone hoses and another stainless 90 elbow.
Looks a bit more factory now, there’s more clearance below the steering arm and it’s stronger and more rigid. Click image to enlarge Click image to enlarge |
13th Feb 2021 12:35pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Not a TD5 but you get the idea. 102mm pipe from airbox to wing tops. DIY adaptor plate covered with a snow cowl. Can’t get much free-er flowing. Been like this for a couple years. Never had a wet air filter. The inlet is raised from the adaptor plate by about 5mm to reduce the risk of water ingress.
Click image to enlarge Click image to enlarge Also gives me good symmetry having a snow cowl either side. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
13th Feb 2021 2:53pm |
Lovely symmetry
13th Feb 2021 3:04pm |
