Home > Technical > Air intake enthusiasts I need you
Page 2 of 2 <12
roel
There is also some restriction in below the air filter. The second water catcher. Roel
2003 90 Td5 (2009-now)
Post #870322 29th Nov 2020 8:17pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Yeah I did the airbox mod too and removed the hyclone thing with my dremel Thumbs Up
Post #870342 29th Nov 2020 9:51pm
Eppilihp
Switzerland
bankz5152 wrote:
Or get rid of the lot including the airbox and use a Honda S200 air filter left under the bonnet
Do you mean something like a cone air filter for a Honda S2000? Is anyone running something like that in a Defender?
Post #874286 23rd Dec 2020 8:29am
LandymanStefan
Was never fully happy with the look of the ducting so just got round to fitting some proper silicone hoses and another stainless 90 elbow.
Looks a bit more factory now, there’s more clearance below the steering arm and it’s stronger and more rigid.
Post #885237 13th Feb 2021 12:35pm
Roy5695
Not a TD5 but you get the idea. 102mm pipe from airbox to wing tops. DIY adaptor plate covered with a snow cowl. Can’t get much free-er flowing. Been like this for a couple years. Never had a wet air filter. The inlet is raised from the adaptor plate by about 5mm to reduce the risk of water ingress.
Also gives me good symmetry having a snow cowl either side. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #885271 13th Feb 2021 2:53pm
LandymanStefan
Lovely symmetry Thumbs Up
Post #885280 13th Feb 2021 3:04pm
Page 2 of 2 <12
