![]() | Home > Maintenance & Modifications > Flexi brake pipe direct to calliper Pros cons |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8222 ![]() ![]() ![]() |
One less join
Caliper comes off easier for hub work. Ran comp vehicles with this setup for 8 years. Now run my training vehicles like this. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Thanks James
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
Did not know this can be done! Mine had an advisory last MOT that this pipe is corroded so needs attention before next MOT. Are there any cons to running them like this? Is the flexi fitting a direct fit to caliper? > 110 XS Double Cab
Make sure it is not stretched on full lock and fully extended Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17727 ![]() ![]() ![]() |
Check also that the flexi hose cannot rub on the rim or tyre under any combination of lock and suspension flex.
There is a reason that LR didn't go straight to the caliper! |
Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 171 ![]() ![]() |
Having been tinkering with LR Defenders for a while now I truly think people give Land Rover way too much credit regarding their engineering. A lot of it seems to have been just scavenging for left over bits.
On topic: Will convert mine to flex lines. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2210 ![]() ![]() ![]() |
Pioneer also does a flexi pipe that replaces the copper one if wanting to keep the OE style set up.
Also be sure the line wont pull on full artic. |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
have llama 4x4 ones with banjo bolts on my ap's
