Home > Maintenance & Modifications > Flexi brake pipe direct to calliper Pros cons
ibexman
I know this mod does away with the bendy breakable pipe but are there an advantages cheers Chris
Post #873501 17th Dec 2020 9:34pm
jst
One less join
Caliper comes off easier for hub work.
Ran comp vehicles with this setup for 8 years. Now run my training vehicles like this. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #873506 17th Dec 2020 9:55pm
ibexman
Thanks James
Post #873511 17th Dec 2020 10:12pm
hank
Did not know this can be done! Mine had an advisory last MOT that this pipe is corroded so needs attention before next MOT. Are there any cons to running them like this? Is the flexi fitting a direct fit to caliper? > 110 XS Double Cab
Post #873518 17th Dec 2020 11:07pm
roel
Make sure it is not stretched on full lock and fully extended Roel
2003 90 Td5 (2009-now)
Post #873562 18th Dec 2020 10:50am
Check also that the flexi hose cannot rub on the rim or tyre under any combination of lock and suspension flex.
There is a reason that LR didn't go straight to the caliper!
Post #873586 18th Dec 2020 2:07pm
Timo K
Finland
Having been tinkering with LR Defenders for a while now I truly think people give Land Rover way too much credit regarding their engineering. A lot of it seems to have been just scavenging for left over bits.
On topic: Will convert mine to flex lines.
Post #873820 20th Dec 2020 10:02am
bankz5152
Pioneer also does a flexi pipe that replaces the copper one if wanting to keep the OE style set up.
Also be sure the line wont pull on full artic.
Post #873845 20th Dec 2020 1:30pm
Likeomg
have llama 4x4 ones with banjo bolts on my ap's
Post #873895 20th Dec 2020 7:45pm
