Home > Td5 > TD5 Not startin! |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Agree with the crank sensor. If you can get hold of a nanocomto see if its reading crank speed would be ideal
23rd Nov 2020 9:50pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
A while ago I forgot to connect the crank sensor after I replaced the clutch. It didn't throw fault codes, but I did get a negative crank speed IIRC.
If you check/replace it, than mind that there's possibly a spacer between the cps and the gearbox housing. https://www.lrworkshop.com/diagrams/land-r...rs_53229#6 J Antares Treadwell, a MY06 110 Td5 in Chawton White |
24th Nov 2020 8:32am |
My td5 wouldn’t start earlier in the year.
Changed crank sensor - no luck Saw the crank sensor wiring was damaged, got Martin on here to make me a stand alone loom from the crank sensor to the ecu - no luck Bought a nanocom, saw it wasn’t seeing a crank speed when turning over... only thing left was the ecu. Bought an ecu on eBay - problem solved. |
2nd Dec 2020 8:31pm |
JohnPaynter Member Since: 23 Nov 2020 Location: Falkirk Scotland Posts: 21 |
ok
i think the next thing to do is check cps wiring is there any easy way to check the wiring? it didnt look too dodgy to me but this thing sat on a site for years so |
3rd Dec 2020 9:09am |
WRLondon Member Since: 04 Dec 2020 Location: london Posts: 2 |
signed up just to say i had a similar issue with a misfire, gave the injector harness a wiggle and it came and went, then found out there’s a plug that’s vertical on the cylinder head, closest corner to front right hand headlight (uk drivers side), inlet manifold side, that was loose, just needed pushing back in!
4th Dec 2020 8:54pm |
Ok thanks ill have a look at that👍
5th Dec 2020 11:07am |
